Question about WatchGuard Technologies Firebox X5000 (WG45000) Firewall
PPTP SETUP x5000
Setup of PPTP
    Problem Solver:
  • 11 Answers
Can you please tell me which version of system manger you are using in the watchguard firewall cuz
now the latest version of firware is 10.2.7 also we are the expert partners of watchguard.
Posted on Mar 27, 2009
How do i turn on the dhcp on my wrt54g2 router
Go to 192.168.1.1
Log into the router (Default username is left blank, password is admin)
On the setup page, make sure "enable DHCP" is checked.
Jun 20, 2011 | Linksys WRT54G2 Wireless Router
Tip
How to setup the D-Link Dir-615 Wireless Router on the Internet 1. You will need...
1. You will need to connect your Cable or DSL modem to the Internet port on your router.
2. Connect your computer to any of the 4 LAN ports
3. Next you will want to insert the "Quick Router Setup Wizard CD" in to your CD-ROM drive. This will take you through the automated steps of setting up your router to work with your modem. Note if you have a DSL modem that uses a PPPoE connection software program you will want to uninstall it from the computer before you continue. Also you will need make sure you know the user name and password because you will need to enter it as a part of the setup for the router.
4. When the setup wizard opens you will want to click on "Install Router" in the upper left hand corner.
5. Click on the option for "Setup Wizard" to use the setup wizard.
6. Click "Launch Internet Connection Setup Wizard" to start to setup your LAN settings
7. Click "Next" to continue.
8. At this point you will be asked to create a new password. After you entered a new password click "Next".
Note it is important to setup a password at this point especially if you plan to setup a wireless network so no one will be able to gain access to your router settings.
9. Click on the drop down menu to select your time zone and click "Next"
10. You will need to select the type on Internet connection you have and click "Next"
11. Here are the different step you need to go through depending on the option you selected above.
DHCP
- If you selected DHCP then you might need to enter the MAC address of the computer that was last connected directly to your modem. If this is the computer you are currently connected to then just click on the "Clone Your PC's MAC Address and then click "Next"
Note you may need to enter a host name if this is required of your ISP.
PPPoE
- This is where you will need to enter your PPPoE user name and password.
Note as a reminder if you have not uninstalled the PPPoE software from your computer because it is not needed any more.
PPTP
- This is where you will need to enter your PPTP user name and password.
L2TP
- This is where you will need to enter your L2TP user name and password.
Static
- You will need to enter the network settings provided by your ISP
After entering the required information click "Next"
12. Click on "Connect" to save your settings. At this point your router should be rebooting. After it is done rebooting then click "Continue". Next you will need to wait 1 to 2 minutes while the router connects to the Internet.
Now you should be connected to the Internet. If you are not connected you may need to review you settings. Also you may try unplugging the power from your modem and the router. Then next plug the modem back in and let it run for about 30 second and then plug the router back in. If you still have trouble you may want to contact your ISP to make sure you have your settings right.
on Apr 26, 2010 | D-Link DIR-615 Wireless Router
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
How to set password to avoid others using my wireless setup?
Enhanced Security with WEP, WPA/WPA2 and Firewall The NBG-417N supports the latest, most secured WPA2 wireless encryption with its one-button encryption setup. It also supports commonly used 64/128-bit WEP, WPA encryptions. It provides stringent protection for wireless transmissions. In addition, the NBG-417N is equipped with firewall features including NAT, Stateful Packet Inspection (SPI), Denial-of-Service (DoS) and VPN Passthrough (IPSec, PPTP, L2TP) to prevent attacks coming from the Internet.
Feb 16, 2011 | Zyxel NBG-417N Wireless Router
Linksis router wont work help me out
First of all contact your isp and get your connection settings. If you are able to setup the router using the cd provided then good. If you are still having problems then go ahead and contact linksys (remember linksys charges for the support). I suggest get a technician to assist you in setting up.
Jul 22, 2009 | Linksys Wireless-G WRT54G Router
Watchguard x5000
Are you doing firmware upgrade? if so your license should not give any error message. If it throws an error you can also reapply the license which you have downloaded from watchgurad.
Jun 07, 2009 | WatchGuard Technologies Firebox X5000...
Wireless connection
On your router seei if you have the ability to setup a PPTP VPN connection. Grant your friend access and share the folders for him/her
Jan 13, 2009 | Dell Inspiron 6000 Notebook
I am doing the setup cd and i am at step 4 connection type- static ip dynamic ip pppoe pptp what on do i need
which type of internet connection are u using ?
plz check the correct box .i think it would be pppoe
Nov 22, 2008 | Toshiba Tecra 730CDT Notebook
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Setting up a PPtP server behind a WRT51AB Router
You?ll need to setup Port Forwarding to set up a PPtP tunnel behind a Linksys router. Please follow these instructions to setup the router to forwarding incoming PPtP traffic to your PPtP server: Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to our Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 47 ~ 47 1723 ~ 1723 IP Address 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application VPN VPN Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue. Restart your computer
Feb 16, 2006 | Linksys WRT51AB Wireless Router
WatchGuard Technologies Firebox X5000 (WG45000) Firewall Logo
149 people viewed this question
Top WatchGuard Technologies Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a WatchGuard Technologies Computer and Internet Expert? Answer questions, earn points and help others
