Question about HP PhotoSmart 145 InkJet Printer
Hp photosmart 145 flashing red light
Just changes the ink cartridge now I have a flash red no go light.
  • 26 Answers
SOURCE: HP DeskJet 722c orange ink light flashing
Try changing the color cartridge. Also it is a good idea to clean the electrical contacts if it looks dirty.Use slightly damp(use water only) q-tips .
Hope this helps
Posted on Mar 28, 2008
iqbal_del
  • 655 Answers
SOURCE: hp psc 1410 all in one
If You have light or message about print cartridge or alignment problems
Cause: The incorrect type of paper is loaded in the paper tray.
  • Solution: The paper must be blank and white for the alignment to succeed.
    If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP
    Support by going to www.hp.com/support. Click Contact HP for information on calling for
    technical support.
Cause: Protective tape is covering the print cartridges.
  • Solution: Gently remove the plastic tape by using the pink pull tab. Do not touch the ink
    nozzles or the copper-colored contacts.
  • Reinsert the print cartridges and verify that they are fully inserted and locked in place.
Cause: The contacts on the print cartridge are not touching the contacts in the print carriage.
  • Solution: Remove and then reinsert the print cartridges. Verify that they are fully inserted and locked in place.
Cause: The print cartridge or sensor is defective.
  • Solution: Contact HP Support. Go to www.hp.com/support. Click Contact HP for information on calling for technical support.
(These help is from HP manual you can refer for details.)
Thanks
Iqbal
Posted on Apr 01, 2008
SOURCE: HP Photosmart 7450 stuck cartridge
not a solution, my paper feeds past the point where printer5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
Replaced drivers as above and still have the same problem.
Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
If I unplug printer from computer, I get same results. Does the driver software install in the printer?
Geo
Posted on Apr 03, 2008
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Posted on Oct 22, 2008
SOURCE: red light on my hp photosmart 7850 keeps flashing
Same problem red light flashing and a picture of a little box with an arrow pointing right in the screen??? what the hell does that mean?
Posted on Nov 08, 2008
I have an HP Photosmart 7260 printer that my cousin gave to me used so I have no manual. I've replaced both ink cartridges and am trying to print. When I send the print job, a red light begins to flash...
Can you see any symbol when the red light flashes? or any message pops up on your computer? Since your problem's description isn't very specific, I am unable to assume myself. If cartridges are replaced with new ones and the problem persists, it's possible that there's paper jam or carriage jam or contacts on the printer is bad/dirty. While the machine is On, lift up the front access door and try moving the carriage manually. Please follow this LINK to clean the contacts.
Please post back with more specific details so that I can help you better. Good Luck.
Feb 18, 2011 | HP PhotoSmart 7260 InkJet Printer
I can't get the red flashing light off.
The red indicator light either means you are out of paper or there is an issue with one of the ink cartridges. Check to insure the the cratridges are installed correctly and that you have paper and hit the cancel buttn. This should stop the red light from flashing.
Jan 02, 2011 | HP Photosmart D5069 InkJet Printer
Blinking red light, unable to turn off or print
From the looks of your printer. I'd say that one of your ink has a problem. The part where you put the cartridge in, is where your problem lies. YOu'll prob need to get it checked out by an HP dealer.
try changing the ink cartridge and see if that helps.
Aug 12, 2009 | HP Photosmart D5160 InkJet Printer
Hp c6180 power light flashing, not booting up
I had the same problem a while back, I eventually had to uninstall everything and then reinstall and it worked fine after that, I have no clue what made it do what it did...thanks Steve
Jun 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
! keeps flashing
Check on the error message that appears on both your monitor and printer....most of the time you run out of paper, a paper jam, or a low ink cartridge....whatever message that is it needs your attention!....cheers
Apr 11, 2009 | HP Photosmart D5160 InkJet Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Ink issue
Normally if it's an ink cartridge problem, you will see there is a small cartridge symbol being shown in the right hand side window. If there isn't a cartidge symbol then it doesn't need a new cartridge. Normally when the red light flashes, it means there is some other problem such as paper jam or no paper! To change the cartridge, open the top of the printer, you'll see the cartridges on the right hand side, they should hopefully just pop out when you pull them GENTLY. To insert a new cartidge, follow the pictures shown and make sure you hear a 'click'.
I am not a techie at all so I hope this helps
Oct 06, 2008 | HP Photosmart 7850 InkJet Printer
HP C3150 error flashing....not printing!
You may have got a bad ink cartridge, I would try changing it again to see if that helps!!
Jun 19, 2008 | HP Photosmart C3150 Printer
Red light flashing-not reading ink cartridge
I have the same proble, except that the red light keeps flashing and nothing happens...
Oct 15, 2007 | HP PhotoSmart 7660 InkJet Printer
HP PhotoSmart 145 InkJet Printer Logo
296 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
