Question about Dell Inspiron All-In-One Computer
Touch screen not properly aligned and often does not respond
Will not recognise finger touch sometimes to get onscreen keyboard or to close programs
  • Dell Master
  • 998 Answers
Display screen mat be defective.
Posted on May 06, 2014
Screen does not respond to touch at times
I find this happens to me sometimes as well.
The screens are capacitive touch sensitive which means it responds to the small amount of electricity on your skin. If your fingers are damp, from sweat, high humidity, then the capacitance will not reach a level for the screen to react to.
Keep your fingers dry and keep the screen very clean and free of oils.
Mar 11, 2015 | Amazon Kindle Paperwhite
Motorola Ex124g screen does not respond properly
Motorola Service center in velachery
No 73, Velachery Main Road,
Velachery, Chennai - 600 042. Motorola Service Center in Velachery Contact 91 87541 77608
May 12, 2017 | Motorola Mobility Ex124g Prepaid Phone
Often when I touch my screen it doesn't respond,why?
did you try calibrating the touch screen? i would first do a hard reset then go to Start> Settings> System tab> Screen> General tab> Align Screen. try using a stylus instead of fingers too! worked for mine
Mar 13, 2011 | HTC TyTN II Smartphone
Garmin iQue M3. Gradually not responding to touch
First make sure the screen is clean of any dirt or oils that may deposit on your screen from your fingers. Use a stylist (a mini pencil like item that came with your GPS) or and other non metal semi pointed item and go through the screen alignment process. Hit the "X's" as you see them (it will move 4 or 5 times to ensure the screen is aligned.) After it is aligned it should give you other options. I have seen GPS's recycle trough the alignment process two or three times before cycling out. If you do this and you are still you are having issues, and you have tried resetting it, you may have a hardware issue.
Mar 07, 2011 | Garmin iQue M3 Pocket PC GPS Receiver
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
My touch screen doesnt respond properly. What could be the probable issue?
tap start>setting>system>screen>align screen, the calibration starts tap on center of +
May 20, 2010 | HTC Touch P3450 Smartphone
Keypad problem in lenovo laptop
hi im josh in cebu phils.may i help you? Friend try to do this solutions it will help you.
Problem: You Type One Key, and a Different Character Appears Onscreen This is an interesting problem with four possible causes:
  • You really didn't type what you thought you did. Look at your fingers. Now look at the screen. Now look at your fingers again. Is everything the way it should be? Good!
  • If you have a programmable keyboard, you or someone else might have reprogrammed the keys so that they don't do what they normally do. Refer to the keyboard's manual for instructions about how to reprogram the keys.
  • If you're in a specific software program, some programs let you reprogram the keyboard from within the program. When you exit the program, your keyboard should be back to normal.
  • It's possible your keyboard is broken. Try hooking another keyboard up to your system and see how it works.
Problem: Your Keyboard Isn't Responding Properly What do you do if you hold down a key and it repeats too fast or too slow? Windows lets you make adjustments to your keyboard via the Keyboard Properties dialog box.
Just open the Control Panel and select Keyboard, and then select the Speed tab. Adjust the Repeat Delay and Repeat Speed settings to your liking, and then test your settings by clicking in the blank box and holding down a key. After you have things adjusted to your liking, click OK.
Problem: Your Wireless Keyboard Isn't Responding Properly This is the same issue as with a wireless mouse—your batteries are getting weak. Replace the batteries in your wireless keyboard to put things right.
It's also possible that you're experiencing interference with some other wireless device. Try moving your wireless receiver or the offending device, or turning off the other device while you're at the computer.
Just try these solutions friend. Hope I helped you Good luck
Mar 10, 2009 | Lenovo 3000 Y410 Notebook
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 | Symbol MC70
Htc touch p3450 is not responding to stylus taps or finger taps
you needto replace the ants which live behind the touch screen
get some fresh once from your garden (or park) if you don't have a garden
Open phone( oh not allowed or warrenty void)
WHAT warrenty?
anywat open phone and you will see a few dead ants behind the screen.
Replace ants with fresh live ones
Close phone (quickly or ants excape)
power on phone
Never do hard reset on phone
It will electrocute some ants
Jan 07, 2009 | HTC Touch P3450 Smartphone
MDA PRO
i have the same unit helps to reset it on a daily basis
Oct 31, 2007 | T-Mobile MDA Pro Smartphone
Dell Inspiron All-In-One Computer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
