Question about BUSlink (DBW1647-FE) DVD RW Dual Layer Burner
Computer will not burn or play disc
When i try to burn a disc it says please enter empty disc and when i try to play a disc it says pleas insert disc in drive
  • BUSlink Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Posted on Feb 25, 2012
Cd's appear to burn but do not play
change your burn software and file formats /if there are music files/
Apr 24, 2012 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
I am new to the computer world & need some help ? How do i transfer my pictures from my computer to a disc ? Thanks
This is for windows 7:
Click the Burn button.
  1. Open your Pictures library from the Start menu and select your desired photos.
  2. Select the photos and folders you want to copy by holding down the Ctrl key and clicking their icons. Or, to select all the photos within a folder, press Ctrl+A.
  3. Need to select photos from multiple folders? Don't select any photos or folders in this step. Proceed with the rest of the burn process and Windows 7 will open an empty window showing the newly inserted disc's contents: nothing. Drag and drop the photos you want to burn into that window. When you're ready, go back to the Pictures Library and click Burn.
  4. Insert a blank CD or DVD into your writable disc drive.
  5. Decide how you want to use the disc:
    1. Like a USB flash drive:
    2. Choose this option when you intend for other PCs to read the disc. Windows 7 treats the disc much like a folder, letting you copy additional photos to the disc later.
    3. With a CD/DVD player: Choose this option to create discs that play on CD and DVD players attached to TVs. Don't choose this unless you plan to view the disc on a TV. You can't add any images to this disc later, so be sure to get them all selected the first time.
  6. Type a name for your disc and click Next.
  7. Click the Burn or Burn to Disc button again, if necessary.
PCHELPSTER007 from youtube. (If I helped you please rate me, if not, feel free to reply)
Jul 06, 2011 | Office Equipment & Supplies
I have tried to update the firmware to 5.50 for my Sony BDP-S300. However, the player still says "cannot play disc". So if it cannot play the disc how can it update.... do I need to get a...
I suggest that you install the latest firmware update to resolve the issue. Please click here to download the latest firmware update. It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder. Most of the customers will be making mistake here after... We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image. I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert
If the player does not play any discs, you can use a head cleaner disc which is available in most of the electronics shop to clean the head before trying the firmware update disc.
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Dec 26, 2010 | Sony BDP-S300 Blu-Ray Disc Player
My Sony BDP S 300 won't play a Blu Ray DVD but will play a regular DVD
Dec 04, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I have a Sony BDP300 Blue Ray DVD Player. It plays non-blue ray dvd's fine. It plays a Celine Dion Blue Ray DVD fine. Tried to play an Netflex Blue Ray Amiela Earhart DVD and get picture but no sound. ...
I suggest that you install the latest firmware update to resolve the issue. Please click the following link to download the latest firmware update.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder. Most of the customers will be making mistake here after... We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image. I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Aug 14, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Disc drive no longer reads discs, when trying to burn error "please insert empty disc" pops every time, regardless of CD inserted.
Assuming you have already tried a cleaning kit, the unit has probably burnt out the laser and will need replaced. Luckily new DVD+R burners can be found for less than $25.
Mar 17, 2010 | Dell Dimension E310 PC Desktop
I want to burn music from MP3 Rocket. It is downloaded but cannot find ANY info on the steps to burn onto CDs.
Open the music you want to burn in Windows Media player... at the top you will find an option to burn the files to disc - this will create an Audio disc that can be played in any CD player.
If you want to back up the Mp3s as data files you should simply insert an empty CD a window will pop up asking you what you want to do - select add files to CD (burn data CD) and then select the MP3s you want to burn... these files will not play on normal CD players.
If this helped you then please help me and vote kindly.
Oct 09, 2009 | Computers & Internet
G-drive media problem
install the drivers for the drive, right click my computer choose manage and then disc manage choose the g drive, right click on it and change the drive letter to w and it will work.
Feb 03, 2008 | G-Technology G-DRIVE (90801201) 250 GB...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
BUSlink (DBW1647-FE) DVD RW Dual Layer Burner Logo
37 people viewed this question
Top BUSlink Computers & Internet Experts
David Payne
David Payne
Are you a BUSlink Computer and Internet Expert? Answer questions, earn points and help others
