Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Disassemble hydro gear transaxle 718-0255a 313.0650
4 Suggested Answers
SOURCE: I have a 25 hp -50 Filling transaxle with fluid?
Hi, I will try to help you. In the rear of the tractor on the right hand side as you stand behind the mower if you get down and look at right over the axle you will see a small hose with a plug in the end of it and that is where you put fluid in. Hope this helps. George
Posted on Apr 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
GodBlessU
  • 3513 Answers
SOURCE: My craftsman tractor model #
Hi
Perform a compression check.The machine is losing power because of a few reasons, carb needs adjustment, governor needs adjustment, or valves need adjustment. However if the engine is missing and losing power, the hill might be too steep. The fuel line comes out of the front of the fuel tank. When going up a hill the fuel runs to the back of the tank and the engine might be starving for fuel. If the hill is more than a 15 degree angle, the engine does not oil properly and the engine will be damaged if this happens regularly.
If the engine is running good but losing power, check the spring that pulls the idler pulley against the drive belt. You might need to move the spring to a different hole in the frame to tighten the belt more.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 29, 2010
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
Ariens model 935335 hydro tractor leaking what appears to be grease or oil out of seal around the axle where it comes out of the transaxle also how to check fluid in the transaxle
look for a dip stick it may be color coded with a yellow end or their may be a tag directing you to were it is located the seal may be bad
Apr 14, 2014 | Ariens Garden
How to put oil in transaxle
You should have a plug in center of axle. Takes 14mm wrench.
Apr 12, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna gear oil
I assume you are referring the the transaxle? The replacement oil in the transaxle is as follows: This model ran either a Hydro-Gear or Tuff-Torque transaxle. If Hydro-Gear use: 20W50 synthetic. If Tuff-Torque use: 10W30 synthetic.
Apr 02, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
Tansmission oil type for model# 917.254740
Your Craftsman is equipped with a Agri-Fab transaxle, the predecessor to the Hydro-Gear brand. The recommended oil is 10w-30. Unfortunately, the transaxle on your craftsman tractor is not serviceable. It is sealed for life. The only way to change the oil is to remove the unit from the tractor, tip it upside down and drain the oil out the reservoir plug.
Jun 16, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
No reverse no 2nd gear no overdrive but it runs in 1st gear and third
a manual transmission or transaxle,if it say, selected shift only works means the problem are the synchronizer of each shift. if mentioned, it was automatic transaxle, the problem is the cluch pack. full down then disassemble the transmission and examine each part for wears. out of spec clearances means problem.
Oct 08, 2011 | Cars & Trucks
Brand new riding lawnmower, stop on hill, set park break, ready to go foward and when I push foward pedal and release break mower free whells backward. has 1 hr. on it. purged the trans. per instructions...
Sorry to hear about your problem...you aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Jul 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Need manual for Victa - 3012TX -11.5HP I/C Industrial - 5 Speed Transaxle - Ride on mower
Check this link out for exploded views ... maybe will help
http://www.krysiak.pl/download_files/MURRAY/31721X88B.PDF
Oct 17, 2010 | Garden
What is the difference in a carrier pin and a park pin, and can I fix this without taking the transaxel out?
They are two totally different pins with different jobs. The carrier pin holds the differential pinion gears sometime called the spider gears in place by pinning their shaft to the differential case. The park pin secures the park pawl to the transaxle case. Neither pin can be changed without removing the transaxle and disassembling it to get to the pins. They are both in the bottom end of the transaxle case on most automatic transaxles.
Jun 08, 2009 | 1994 Ford Taurus
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
403 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
