Question about John Deere Garden
2000 John deere 6310 pto wiring diagram - John Deere Garden
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
Posted on Oct 30, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
I have a John Deere GT275 that keeps blowing the F3 15A fuse. Any suggestions why?
Get a wiring diagrams and trace down each component the fuse powers and its wiring and find the short, no other way to fix it.
Jul 12, 2017 | John Deere Garden
JD 345 pto will not turn on.
What you need are wiring diagrams, not schematics, and you will have to inquire directly to John Deere.
Jul 20, 2016 | John Deere Garden
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
Wiring diagram john deere 260 lawn garden tractor
John Deere will be the best place unless you luck out and a John Deere mechanic or someone with a service manual reads this and responds.
Oct 04, 2014 | Garden
How do i fix a LA 145 john deere pto clutch wiring
If you can't find a wiring diagram, no problem. Follow the wiring to where it was ripped out. If it's your lights it's usually a black (ground) and a brown or brown with stripe for the lights.
Another way would be to just match the wires on both sides where they were ripped out. Example: RED TO RED, BLACK TO BLACK, etc. Make sure any wire with a stripe matches.
Sep 13, 2014 | John Deere Garden
I have a john deere 420 that the pto will not engage. I do have power at the switch
You are going to need to Google John Deere 420 wiring diagram. There is a 30 amp fuse in the PTO power circuit. This provides the power to the Time Delay Control Module which has the solenoid in it. Any chance you can here the slonoid click? There, is a safety interlock switch on the seat. And everything goes to a common ground lug that may be corroded or loose. If the PTO light comes on but dim, then start with the ground. Quite a lot in this circuit.
Dec 14, 2013 | Garden
John Deere 4410 PTO error code. One long flash, one short flash and then six short flashes.
Check the wires on the solenoids.
http://www.tractorbynet.com/forums/attachments/john-deere-owning-operating/39426d1117768879-4410-power-take-off-stopped-665916-solenoids.jpg
Items L, M, N are mid PTO, MFWD, and rear PTO respectively
Also look at the skid plates as the possible cause of wire damage. A cheap spot / zip tie will keep the wires away from any future damage. Often the wires are damaged / torn off by a foreign object striking the Solenoid.
Thanks for choosing FixYa,
Kelly
Jun 19, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
I have a John Deere l130 and the mower blades engage when I start the engine even when the PTO switch is off. Any suggestions?
sounds like you have feed going directly from switch as soon as you turn ingition to start mode ?
check wiring back from electric clutch to main switch
possible 2 wires have been placed on main switch instead of pto switch ?
or you have a crossed circuit somewhere (that is feed from another live circuit) not directly connected and its ended up at electric clutch as soon as you liven main circuit
a wiring diagram may help
check with www.johndeere.com
or www.jdparts and enter their site load your model and type
and go to electrical system and print out a copy of wiring diagarm
you may need to supply and user name and apply for password from john deere via their site apply on line
its a good site for info and parts diagrams
cheers hope it helps
paul
Aug 05, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
John Deere LX255 PTO stopped
My John Deer LX255 will not engage the blades unplugged yellow switch and cleaned spades. What should I do next?
Apr 21, 2010 | Garden
Garden Logo
91 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
