Question about Coleman Heating & Cooling
I need a wiring diagram for a coleman rv furnace
Buffalo12980
  • 625 Answers
SOURCE: colman furnace
look on your burner control relay - look for terminals marked T and TH.  connect up a honeywell thermostat here.
Posted on Oct 15, 2007
  • 4 Answers
SOURCE: Fix for coleman rv furnace
Check all limit switches and check power to gas control
Posted on Jan 06, 2009
tborn6
  • 700 Answers
SOURCE: Need wiring diagram
here would be the hook ups that are needed. at the air handler
r-red
g-green
c-common
w1/w2/aux-white (DEPENDS ON WHAT TYPE OF SYSTEM YOIU HAVE)
then these are what goes to the outside unit
y-ylw
o- org/or b-blue
c-white
r-red
personally contact me if yopu still have questions. thanks
Posted on Jan 12, 2009
  • 8 Answers
SOURCE: wiring from thermostat to furnace
Typically you normally will have five wires controlling your furnace and airconditioning. R Y W G C. If you get some thermostat wire. Connect them like this---- red wire will go to R(this is your 24V to thermostat)----yellow wire will go Y(Y is your cooling)----white wire will go W(W is for heating)---green wire to G(green is your fan)---black can go to C(this is your common to supply 24Vto thermostat)
Posted on Jan 19, 2009
atocrxr
  • 135 Answers
SOURCE: install automatic ignition system for a coleman furnace
For sure turn off the power at the breaker!! Now as far as the new board, usually the new board will be a new modified replacement, the wiring will be different from the original. It is very important to follow the installation instruction that come with the new board, if you go step by step, it will be ok. Just don't be surprised when you find that the new one is not exact. It is all in the name of improvement, follow the install manuals, step by step. As a 30 year Heating and cooling tech, it was very worrisome when they started doing this, but as long as you have a board that matches the brand and model of your furnace, it will be ok.
Good Luck,
Paul Gibson
Posted on Mar 31, 2010
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
Wiring diagram for gas furnace COLEMAN
Alvaro, can you give me the model number of the Coleman Furnace you are needing this diagram for?
Dec 20, 2013 | Cars & Trucks
My rv furnace want start up i changed ac units new don't have the relay box build in it how do i rewire the furnace ?
Shooting from the hip here, but look at both the new and old wiring diagrams. Chances are that the new unit has terminal leads that would connect to the old units' relay/control box and you simply need to install the old box on the new A/C by connecting to the correct terminals. beyond that, you can build your own relay setup if you understand wiring diagrams. If you don't know wiring, I'd recomend taking to an RV shop, as you can damage either the A/C or the furnace or both if wired incorrectly... Hope this helped!
Mar 26, 2013 | Heating & Cooling
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
