Question about Fisher and Paykel Washing Machines
What is wrong with my Fisher Paykel washer?
I asked a question yesterday about a 2010 Fisher Paykel washer that will not spin or agitate, but will drain the water. Someone named Robert was offering a solution to the problem when a winter storm hit and the power surged into the computer. I have lost the solution. Could Robert or anyone who can help me, please respond as soon as possible. Thanks in advance.
  • Fisher and P... Expert
  • 554 Answers
With the power off at the wall, can you turn the bowl by hand easily
Does the bowl stir when filling.
Will the bowl lift and disengage from the spline drive when low water level is reached so agitator can turn freely.
If any of these it could be bowl or spline drive and spigot.
Posted on Dec 26, 2013
fanny
  • 146 Answers
SOURCE: fisher paykel washer
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
  • 1314 Answers
SOURCE: Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Posted on Feb 16, 2008
Thank you, thank you, thank you fanny! That was so easy! I can't believe I just fixed my washer in 5 minutes!
Posted on Jun 26, 2008
SOURCE: Fisher Paykel washing machine GWL10
Had the same problem with some other appliances. If you're not afraid to open the washer up, it's likely there's a fuse that has blown. If you can find a source for the EXACT same fuse (specs on the body of the fuse), replace it, or you may wish to risk a house fire by bridging the fuse with a piece of electronics solder.
Posted on Aug 13, 2008
Karthik316
  • 187 Answers
SOURCE: lights on but wont start- can I reset it model GW608 fisher &paykel
  • Hi,
  • try these:
  1. Check that the washer is plugged in securely
  2. Check the circuit breaker or fuse box
  3. Test the outlet for current
  4. Check that the water supply valves are turned on
  5. Inspect the filter screens
  6. Test for overheating
  7. Test the water level switch
  8. Test the timer control
  9. Test the lid switch
  10. Test the water inlet valve
  11. Inspect the water pump
  12. Test the centrifugal switch
  13. Test the motor
please rate my suggestion....
Posted on May 22, 2009
Can't secure agitator wingnut on 7.5kg Fisher & Paykel top loader.
try rotating the agitator some and see if it drops into place on the shaft .
Oct 26, 2015 | Fisher and Paykel Washing Machines
Fisher Paykel GWL 15 Rotor Position Sensor
Does It just shake bowl left & right, it will soon give you fault code 56.
Well its a board problem you will need to get technician to fix this board, three resistors(R129,R130,R131) need to be changed for a 1MegOhm resistor.
Jul 08, 2012 | Fisher and Paykel GWL11 Top Load Washer
I still need help with my previous issue. My F&P
Hello, one off the first things in order to help would be the model number this way we are able to see which type of washher you do have. If this were a smartdrive type unit we could use something like this service manual click this link http://www.docstoc.com/docs/25379715/Fisher-_-Paykel-Washer-Diagnostic-Fault-Codes in which on this type of fisher and paykel washer you would count from left to right the 8 lights and list which led's were lit on the unit. There are of course other service manuals depending on which model you do have. I await your reply to the model number of your machine and if I dont see your response this evening I will look forward to answering any further questions you may have tomorrow. Thanks
Rick
Aug 25, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel ecs washing machine.The agitator dosen`t turn any more so the clothes aren`t getting clean.The spin is working ok.What could the problem be??
This can a problem with the program controller unit as during the cycle there is no power to the motor so as to agitate.
You will need to check the controller , try with another program if not check the output when the wash cycle is on.
Feb 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
THE WINGS ON THE AGITATOR ON MY FISHER PAYKEL ECOSMART TOP LOAD WASHER ARE BREAKING OFF. CAN I REPLACE THIS EASILY?
yes loosen the wing nut nd remove nd replace , u can order part from F&P direct 1800650590 ask for spares
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel won't finish spin cycle
To remove the tub you need to remove the spin motor magnets and stator, then using a tube soket undo the tub nut and it will come out. (not EASY JOB)
Sep 17, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
48 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
