Question about HP Photosmart C5180 All-In-One InkJet Printer
Printer will not complete boot. It looks like it begins to boot, then power light goes out but comes on again
The bar on the bottom of the display screen indicates there is progress. There is no other sounds, cleaning heads or ink refilling. It's in this state for about 5-6 sec. The display freezes, goes dim, the power light goes off, the red exclamation button alights, then the whole thing begins again.
    Sergeant:
  • HP Expert
  • 350 Answers
Most probably caused by a power supply failure or main board short. Either way it is not a repairable fault.
Posted on Jan 04, 2018
hvpatel
  • 152 Answers
SOURCE: Refilled ink cartridges: printer stopped working completely. Can't even install it!
may be your refilled ink cartridge fail so replace with new cartridge
Posted on Feb 28, 2008
SOURCE: HP 6310: memory card light flashing, printer will not turn on.
Need to reset Firmware
Posted on Jun 11, 2008
sagarjd
  • 95 Answers
SOURCE: Problem with HP PSC 1415 printer on inserting refilled ink cartridge
Check this link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00005109&dlc=en&product=441115
Regards,
Sagarjd
Posted on Aug 01, 2008
  • 291 Answers
SOURCE: HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
Posted on Nov 23, 2008
  • 97 Answers
SOURCE: HP C6180 boot - init loop / power on-off loop
The Formatter board (main logic board) is faulty. You need to take the printer in for repairs to HP, in my experience though it usually works out better to replace the printer.
Posted on Aug 19, 2009
Testimonial: "Thanks for your expertise. It's shameful though, because I have recently bought new cartridges. New printer means new cartridges."
Printers LCD light stays on and blinks, printer will not turn on
Inkjet / Laser / Dotmatrix / Daisywheel / Make / Model?
Nov 18, 2017 | Office Equipment & Supplies
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
Dear sir My sony vaio grx570 do not turn on properly. 1-if keep it up off for one day, it does not starts booting. but after 5 to 6 tries it get power on with AC power. Windows xp logo...
When you boot the machine, use the proper key to enter the BIOS and check the date and time. If it is wrong then the BIOS battery is bad. Replace it.
Mar 03, 2017 | Sony VAIO GRX550 Notebook
No display lights
Run the PSA Diagnostics and Obtain the PSA Error Code
To run the PSA diagnostics and obtain the PSA error code, perform the following steps:
Shutdown the computer.
Press and hold the <Fn> key, then press and release the power button.
Release the <Fn> key when the lock lights above the keyboard begin to flash or Diagnostic boot selected is displayed in the upper right corner of the screen.
Release the <Fn> key.
The PSA diagnostics sequence begins.
After approximately 2 minutes the system produces a number of alert tones.
After the alert tones, the system produces either a series of low beeps or error codes.
Note:
PSA diagnostics will prompt for input during some tests. The resulting error message does not necessarily indicate hardware failure.
For example, input is required during the color bar test. Failure to input a response will eventually result in a timeout error: 1000-0333 Graphics test timed out waiting for keyboard response. This does not indicate a graphics failure has occurred.
Note the sequence of beeps or error codes.
Initialize LCD BIST Diagnostics
You can initialize the LCD Built-in Self Test (BIST) in two ways, depending on the revision of Pre-boot System Assessment (PSA) diagnostics:
PSA versions 3019 and greater run LCD BIST immediately after failing the color bar test, via user input of <N> or waiting for it to time out prior to generating the 3-3-3 or 3-3-4 error. PSA version 3019 became available in November 2005 on various Dell laptops. The PSA version is upgraded with the BIOS.
With older versions of PSA diagnostics prior to November 2005, LCD BIST runs after responding with a <Y> after receiving a 3-3-3 or 3-3-4 error code.
To initiate the LCD BIST on PSA versions 3019 and greater:
Boot to the PSA Diagnostics.
Watch the screen and listen for the color bar test prompt tones emitted by the PSA Diagnostics. If the screen is visible, one will see the PSA diagnostics draw a series of multi-colored bars across the screen. When completed, a prompt asking if the pattern was seen appears, accompanied by a brief series of tones.
Press <N> or wait approximately 30 seconds to fail the color bar test.
Watch for the LCD BIST color generation and listen for the beeps every 2 seconds that indicate LCD BIST is running.
LCD BIST runs for approximately 20 seconds, then stops. The 3-3-3 or 3-3-4 error code is then displayed when the LCD BIST is complete. If LCD BIST does not initialize, then the system may not have been upgraded to PSA version 3019.
To initiate LCD BIST on systems with PSA versions prior to 3019:
The system emits a 3-3-3 or 3-3-4 PSA error after failing the color bar test. Wait for two iterations of the failure code and then press <Y>.
Note:
On a working LCD, the PSA diagnostics shows the following message:
Error Detected, continue testing? Yes or No or Retry.
Watch for the BIST color generation and listen for the single beeps that indicate LCD BIST is running.
Patterns of flashing color should appear on the screen. With every color change, an audible beep is heard. If the patterns of color do not appear, and the beeps are audible, an LCD failure may be the issue. If the patterns of color appear, a video card or motherboard failure may be the issue.
IF AN ERROR IS INDICATED, PLEASE CALL DELL SO YOU CAN SEND SYSTEM TO SERVICE DEPOT FOR REPAIR (WE'VE JUST TRIED TO ISOLATE ISSUE TO SEE IF ERROR IS CAUSED BY HARDWARE OR SOFTWARE, OR JUST SOME CONFIGURATIONS)
Thanks and Goood luck! =)
Jan 03, 2009 | Dell Inspiron 9100 Notebook
Boots halfway and dies
One from all problems can be:
Hdd problem or power suply
If u have another hdd change it and try
Let me know if u got help?
Nov 27, 2007 | Dell Inspiron 1100 Notebook
Laptop troubles
I will reinstall windows XP, or your batery Bios is completely dead
Aug 27, 2007 | HP Pavilion ze2000 Notebook
Scanning problem
here is the service manual for your printer
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
it has trouble shooting and step by step repair instructions
Aug 14, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Printer will not finish 'booting up'
remove the power cable directly from the back of the printer, press and hold # and 9 while holding both these buttons put the power cable back to the printer. now let the buttons go when the on light starts flashing
Dec 28, 2006 | HP OfficeJet 7410 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
