Question about Canon Pixma iP4500 InkJet Printer
Canon PIXMA ip4500 will not turn on
I was printing out a color paper and then all of the sudden, when it finished, it didn't eject the paper, and it was dead. Now I can not turn it on and there is no green light. I've tried plugging it in to a couple different outlets and no success. I've held down the on button for 30 secs or so and nothing.
2 Suggested Answers
  • 3278 Answers
SOURCE: Canon PIXMA ip4500 will not turn on
Sounds like the power outage was a power surge and destroyed your printer, especially if your printer was not plugged into a power surge protector strip. Check with others in your apartment to see if they experienced the same. If so, your landlord may be responsible and can put in a claim. If your printer is still under warranty, contact Canon. Also, check to see if this item is covered by tenant insurance, if you have coverage. Hope this helps.
Posted on Jul 16, 2009
Canon iP4500 colour management
Try this setting. This might be different but try to point some similar preferences and steps then you can give it a try.
Open Control Panel (I'm assuming that the OS is Windows XP) click on Printers and Faxes.
Right click the Canon iP4500
Click Properties in the drop down menu.
Click on the tab Color Management
There should be a list of color profiles if the drivers were installed properly.
They are-
(Generic)
(Matte Photo Paper)
(Photo Paper Pro)
(Photo Paper Pro Matte)
(Photo Paper Plus Glossy)
The last profile is the one you want. Just above you will see the choice of "Automatic" or "Manual". Click on Manual and this force the printer to use the highlighted profile for all printing jobs.
Now click on DEFAULT.
Go back to the main Properties page and click on the General tab.
Near the bottom you will see "Printing Preferences"
click on that.
You should now be in a Canon ip4500 Printing preferences window.
Look for Print Quality and click "Manual"
Click on "Set"
Click on "Diffusion" and just above that there is a slider that should be all the way to the right.
Click "OK" to save the settings.
Now just below you will see "Color Settings"
Click "Custom" and then "Set"
Everyone sees colors a little different but the following settings print a photo that folks I show them too really like the balance of.
Cyan 4
Magenta -12
Yellow 0
Black 0
Intensity Slider in the middle
Enable ICM not checked (disabled)
Print Type set to Photo (you might want to try the other settings here to see how the prints look to your eyes)
Brightness Normal
Click OK to save settings and return to the Main Menu.
If you now go under the Profiles tab you should see you new profile there.
You can give it a special name like "Canon Excellent Profile Settings" clip_image001.gifor some other easy to remember name. This is the profile you want to use when you print a photo.
That is it...simple eh?
Now the other important part is in PhotoShop/PS Elements. Open the program and then open any old photo.
Under File, scroll down to Print Preview and click
If not open, click on "Show More Options"
Bring up "Color Management" in the box just below the "Show More Options"
For "Source Space" click ""Document"
This setting depend on the profile you shoot in, either Adobe RGB or sRGB. You choose the one you use.
Below that there is a setting for "Print Space"
You want to match that to your source, whether Adobe RGB or sRGB.
For the "Intent" letting I choose Perceptual.
Then click "Use Black Point Compensation" and that is it. Ready to print
Aug 08, 2008 | Canon Pixma iP4500 InkJet Printer
Canon pixma ip4500 cannot install drivers, 'cause gives the error - "printer not detected", even though it's ON and conected to the PC.
Hello how are you.
If you install windows 7 when you turn on the USB cable to the driver you downloaded from the Internet.If windows finds himself then the problem is the USB turntable.
Call the appropriate Canon printer service.
Dec 16, 2012 | Canon Pixma iP4500 InkJet Printer
Hi there I have the original canon cartridges in the printer and they all have lots of ink in them, but suddenly when printing the 'black' parts of a photograph looks purple. But when I print text in...
When you are printing a photograph, the back is resultant of combination of RGB but when you print a latter of document it usages only the black ink. So since the black is properly printed when it's combining RGB that means any of the color is low on ink. Replacing the color cartridge will solve the problem for you.
Mar 15, 2011 | Canon Pixma iP4500 InkJet Printer
Service error 6A00
Hello thanks for using fixya.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma iP4500 InkJet Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
See my this "Solution" same as your's & 3 people thought that it was helpful for them
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 14, 2011 | Canon Pixma iP4500 InkJet Printer
My canon iP4500 will not use black ink on photopaper. If I tell it the paper is plain then it prints fine. If I tell it the paper is any type of photopaper the colours are great but there is no black ink...
If you set Plain paper with Greyscale printing, only the black Pigment tank is used.
If you set any other paper type, only the 4 Dye tanks are used - even if set to Greyscale.
Dec 09, 2010 | Canon Pixma iP4500 InkJet Printer
My Canon iP4500 does not print with "black" cartridge
hi im josh in cebu phils. may i help you? Friend the problem is your cartridge and on the tank lever.it causes spoiled ink that stuck on it. To solve this problem. you may visit the Cannon Pixma support manual site and follow the steps there:here:
http://www.generalmanual.com/Printers/Canon-PIXMA-iP4500-Photo-Printer.htm
good luck friend hope i helped you.
Mar 14, 2009 | Canon Pixma iP4500 InkJet Printer
Hi, my canon pixma mp450 is not feeding the paper thru properly.
We had the same problem so we opened the screws up at the back, gave it a shake and suddenly a asweet wrapper appeared. We then put the screws back in and it started printing again! Good Luck!
Jan 16, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma iP4500 InkJet Printer Logo
76 people viewed this question
old marine
old marine
