Question about NAD C542 CD Player
No disc All attempts to make the machine see a disc fail. Has not been used for a whil, under a year old with light use. After loading a disc, the cursor flashes for 10 to 20 secs and then reads 'no disc'. No sound comes from the machine during this process. Any suggestions
    President:
  • 3,130 Answers
Try using a cleaning disc, if that doesnt work take apart the unit and manually clean the lens. If that doesnt work your going to have to take the unit in for an estimate. If its more then two year old and you paid less then 150 bucks for it , it probably is not worth the estimate fee. good Luck
Posted on Aug 26, 2006
My Masterlink is 7 years old. Do I need to replace my hard drive? How many hard drives, make and models? Thank you. Bill Dorsher
Any 3.5" IDE hard drive will do, it doesn't need to be a large one, as the Alesis will only 'see' the space it needs to - google 'standard ML9600 hard drive size' to see, I can't recall offhand.
You don't HAVE to upgrade the OS if the machine is working fine. You WILL have to install it on a new HDD if you install one.
For what it's worth, I could only get the OS to install from a disc I made on a Windows XP PC. Three or four attempts from a Vista machine all failed. Win 7 and 8 are unknown territory for me.
Make certain you have an OS disc BEFORE you replace the HDD.
Mar 07, 2015 | Alesis MasterLink ML-9600
Wat does blue light flashing under washine machine wen it goes into spin
sounds like its the moter! when it goes in to spin the carbon brushes makes sparks and would prob do this but it normaly does it when the machine has been working a year aprox depending on use! it should not do this if its new or a month old! if under warrenty i would call them to get it checked as sparks is not good!
Feb 28, 2013 | Hoover AAA160 Front Load Washer
Okay, i know that this is a common problem for several years...when i try to burn a disc in itunes, it "checks playlist", and prepares to burn, but then cancels burn and gives me this error...
> this drive worked for about four months
> I cannot burn a disc ... even with other programs.
It must have "failed".
The "good" news is that it probably can be replaced, under WARRANTY.
Take it back to where you purchased it, and they will replace it, under WARRANTY.
> could not recognize the drive
The drive has several major components:
* the electronics that tell the computer that it exists, and is CD-ROM or CD-RW or DVD-writer,
* the laser that heats the surface of the media, to "burn" onto the media
In the first case, the electronics failed. In your current case, the laser has failed.
Apr 23, 2011 | Apple iTunes
I have an AEG 6955 washing maching about 14 years old. Recently the program has stopped on many occasions with code F1 usually on first fill. Other times it works OK. The manual says this is no water....
Yes changeing the valve will fix it . around £30. On one occaision only I have come across the detergent dispensor top being blocked up enough to slow down the fill. on your machine it allows 5mins if this is exceeded F1 is displayed and prog stopped.
Nov 15, 2010 | AEG Lavamat 88840 Front Load Washer
A cdr630 twelve years old will not record on any blank discs optical fail on maxell tdk and all brands.do you know what discs i can buy for this machine.marantz state discs with a green dye but i cannot...
The manual states that 74 minute 650MB 1-4X disks run best; my machine would not burn anything I had, eventually I found 650MB crrw's on ebay for as cheap as 2 cents a piece, I have a fair number of them and so far every single one has worked. Imation 800Mb cd's seem to work 80% for me.
May 20, 2010 | Marantz CDR631 CD Recorder
Irregular performance...
sounds to me like your laser is gone.
Some discs are harder to play than others as some are multilayed, check online as to whether it is suitable to use laser cleaners these are like discs with soft brushes attached, you can get them from pretty much any computing place, i wouldnt know whether its sensible to use on a DVD player, but couldnt hurt anymore eh?
Jan 08, 2009 | Sony DAV-S500 System
WASHER SOUNDS LIKE AN AIRPLANE TAKING OFF DURING SPINE CYCLE
Most likely a failed "spinner" assy. The roaring that you hear is the bearing telling you it's had enough and has gone on strike.
MAJOR job! If it's over 5 years old, I recommend calling a professional and get quotes. Then decide what you want to do.
If it's less than 5 years old, it should be under warranty. Contact Sears. Tell them you have a failed spinner and tub bearing assy. and have them do the repair.
*Just a quick note. You should use only HE detergent in these machines.
Tracy
Oct 28, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
WASHING MECHEN PROBLEM ELECTROLUX
Hi DRVBM
Welcome to fixya.
I'm Huuum and happy to assist you,
Tuk Tuk or banging may mean several things.
Uneven load or over load of cloths, meaning to mush inside at one time.
Or if it is a top load washer and, an old washer it may have a bad coupling connect in it to the transmission .
What's the model number, year of washer and slowly describe the issue!
with the answers to the above questions I may help you more!
Check these!
Is the load balanced and the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
Huuum ,
Please leave a rating at the end
Sep 26, 2008 | Washing Machines
Latitude d600
Dave,
At this point the virus, and it was a virus no doubt, has done irreparable damage to the operating system, and possible the hard drive. You will need an operating system disc, no way around that. Once you have the disc, then you will need to reformat the hard drive using the full NTFS format, not the quick format, to ensure total deletion of the virus, and install a new operating system. If the hard drive won't format or if you have any issues during or after the install, then the hard drive has or is failing and will need replaced. If you need any futher asststance with this just ask.
Aug 29, 2008 | Dell Latitude D600 Notebook
Drum bearings,
if your machine is under 5 years old ...the machine is under warranty for parts only and is covered by hotpoint they will charge you for callout/ labour charge only..you need your date of purchase proof or go by the manufacturing date code inside the door the first two digits of eight.... this month is 73 so deduct the first two digits from that number eg if the digits were say 43 take that from 73 hence 30 months old from production my guess is the machine is pehaps 2 years old typicall failing for that model... .for you to buy the parts and do it yourself major stripdown! will cost you the same as their (hotpoints charge) so i would call them hope this helps
Jan 26, 2008 | Hotpoint First Edition FEW12 Front Load...
NAD C542 CD Player Logo
298 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
