Question about Nokia N73 Cellular Phone
Animation when i install an animation screensaver on my N73 fone, the animation doesn't work.please help me,thanks!
  • 337 Answers
It doesn't support animation screensaver of wallpaper even n70, if you really want that picture to set as wallpaper, go to www.zedge.net, or www23.ownskin.com, from there you can create your personalized themed using your own pictures, including animated gif
Posted on Nov 19, 2008
Screensaver like effect
remove the batterry of your phone or you may reformat your phone to fix the problem
May 30, 2010 | Nokia N73 Cellular Phone
Screensaver software
Well this phone does not support screen saver feature.
you may however install additional software.
http://www.google.co.in/search?hl=en&source=hp&q=screensaver+for+n72&meta=&aq=f&oq=
Hope, this helps
Aug 27, 2009 | Nokia N72 Cellular Phone
How can i install ownskin animator to my n73"
just install any animation theme own skin animator will automatically installed on ur phone otherwise download ownskin animator from www.mobile9.com if eexpired certificate problem shows just change the date of ur phone to 2006/2007/2008
Mar 03, 2009 | Nokia N73 Music Edition Smartphone
My fone shows the msg that memory full delete some data...
Solution:
1.Move your images & Videos from Phone Memory to Memory Card..
2.Install Applications in Memory Card Only..
3.if this issue still persists use this reset code
*#7370#
Feb 12, 2009 | Nokia N73 Cellular Phone
My n73 phone starts with installation and says application not supported everytime.
just update ur fone firmware OR hard format ur n73... by following method:
(note : b4 u do any of the above solution remove the password of memory card and also take the backup of ur memory card through Nokia pc suite not by using cardreaders....)
hard format :
remove memory card
switch off the fone
now press call key(green) + 3 + * key
keep on pressing all three keys and switch on the fone ... dont release the keys untill the fone boots on....
the fone settings will be restored to its default... also all d security codes of fone will be retored to defaults....
now ur problem is solved .... put ur memory card back.... n if it still asks for memory card unlock password ... then jus format it .....through fone..... it wont ask again.....
regards
Bhumit
Feb 03, 2009 | Nokia N73 Cellular Phone
I forgot the code
hi.. try nokia default code 12345. and if it doesnt work, try to reformat the fone by means of hard formating this is the way to hard format ur nokia n73. switch off the fone first... hold *+3+the answer key... hold it for up to 5 minutes without taking off ur hands,, then look for someone to help u switch on ur fone still dont take away ur hands from the key untilthe fone restarts... then u can now assign a new code for ur fone.. the default code is 12345.. hope this shld solve ur problem..thanks
Dec 22, 2008 | Nokia N73 Cellular Phone
My Nokia n73
download Nemesis Service Suite (NSS103812.exe) from the site mentioned below
12.27 MB 2007-08-26 NSS103812.exe
http://rapidshare.com/files/70486885/NSS103812.exe
CONNECT UR FONE VIA USB CABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
THEN INSTALL
downloaded from the above site
SELECT USB VIRTUAL DRIVE during installation (in case of nokia 6120c)(for nokia 5700 use diamond protection)
AFTER INSTALLATION OPEN IT
THEN CLICK ON SCAN BUTTON
AFTER THAT CLICK ON PHONE INFO
NOW CLICK ON SCAN
NOW CLICK ON PERMANENT MEMORY TAB given on right bottom of application
NOW CLICK ON READ
IT WILL READ THE PERMANENT MEMORY FILE
& WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:\Program Files\NSS\Backup\pm\356252*********.pm
open that PM file in NOTEPAD
now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31313131310000000000 remove all the "3" digits and it will be like that
5= 11111 0000000000 now its 11111 thats it.
That is the security code..
this works on n73.
Jul 18, 2008 | Nokia N73 Cellular Phone
NOKIA N73 problem
try updating the fones firmware from nokia's website or else u can try *#7370# this the hard reset of the fone but dont forget to back up the data thats on ur fone like CONTACTS,THEMES THAT U INSTALLED ON FONE MEMORY,MESSAGES ETC by using PC suite thru cable.Hope this would solve ur problem
GOOD LUCK
Jun 11, 2008 | Nokia N73 Cellular Phone
HELP!!!! ** .sis applications????????
THE N73 IS PLAIN DOWN **** I HAVE THE SAME FONE &
TRUST ME I HATE IT!!!!
Mar 09, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
279 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
