Question about Krell Audio Players & Recorders
Krell FPB300 When hot there is a noise coming inside the amp but not affectinng the sound
I have a Krell FPB 300 amplifier use to power my martin logan SL3 speakers. When the amp is about 1.5 hours running you will hear noise coming from inside the amp sounds like a small motor( the amp has no fan) but when you stop playing music and idle it it will lower the sound and when you put music back it will be there again, and it does not affect the sound.But on the first hour there is no noise at all. Please give some advise.
  • 31 Answers
SOURCE: krell 250a power amp
Hi There WLAW,
I am in Auckland NZ and do repair work for a high quality Amplifier chain so I could have a look at yours for you....
Being Local in Auckland it will save you sending it away off shore to Australia.
Cheers From YUBEUT (09) 357 7496
Posted on Dec 26, 2007
  • 4 Answers
SOURCE: krell kav300i, increasing volume by itself.
I have 20 year exp. with Krell. Contact me directly.
Steven Leckrone
The Service Department
203-331-0671
sleckrone@snet.net
Posted on Oct 22, 2008
jomabug76
  • 1148 Answers
SOURCE: Just stopped working. Checked connections and power button no luck
take off the lid and check the fuse,,,
Posted on May 17, 2009
  • 12 Answers
SOURCE: krell kav 250A blows internal fuse
hi please check the wiring of the output it could be short or the speaker would be short or it could be the diode at the secondary supply that had short or capacitor disconnect the power supply ans check the OHMS of the transformer .or check the transistor could be stort
Posted on Nov 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hi, Will the krell kav 500i work on 220v 50hz
If it has a voltage selector for 220v, once configured it will work just fine Being electronic instead of mechanical the power frequency won't affect it. If it doesn't have a voltage selctor, don't plug it into 220.
Posted on Dec 26, 2009
Krell 2250 was operating well .. Suddenly left channel stopped .. checked the fuses all ok .. Any idea. ?
try subbing out another newer speaker for the left one ? if sound returns then that older speaker is defective .
Nov 12, 2016 | Krell Audio Players & Recorders
Where can I get a fuse for my Krell KSA 300 amplifier.I had a blown fuse on the left channel.
Fuses rarely go on their own. The cause is likely to be a shorted semiconductor device in the left channel output.
Fuses are generally not specific to any brand. Is the fuse a tube with metal ends? If it is measure the length in MM. Then look at the end and you should see the rating. Either in A for Amps or MA for milliamps.
Any electronic parts supplier should have the one you want in stock. Buy several, for if the part I mentioned has gone, it will blow again.
Sep 09, 2016 | Krell Audio Players & Recorders
How do I brigde a krell show case amp from 5 channels to three channels
Thai will require removal of the top cover to move jumpers or program dip switches in proper order. This will be explained in the owners manual which is located at Krells web site.
Steven Leckrone
30 Unquowa Hill St
Bridgeport CT 06604
203-331-0671
Steven@theservicedepartmentct.com
www.theservicedepartmentct.com
Nov 14, 2014 | Krell Audio Players & Recorders
Hi, I have to replace all the 20 transistor of my krell kst-100 power amplifier- wich are the best choice? model and company? maybe mj21195g and 6 from onsemi?
Onsemi ( which is motorola) is a good pic for replacements If youre looking at the 21195 , then there must be a compliment to that as well? 21194 or 21196
Oct 10, 2010 | Krell KAV-300i 2-Channel Amplifier
Hello, after plugging on Ipod through my preamp hooked through my krell kav 300 integrated amp I heard a super loud noise and lost power. I examined the fuse and it looks fine. What do I do?
Sounds like the volume was way up when the iPod turned on. iPods are DC and cause a sudden thump through the speakers when they power on.
If the fuse is not blown, there may be another fuse you have not seen. Most amps have three to five fuses especially a 150watt/channel like the Krell.
Apr 17, 2010 | Krell KAV-300i 2-Channel Amplifier
Wiring Diagram required
At this point you may have fried the output stage. Is there a specific model listed on the back? I need that to locate the schematic.
Thanks,
Dan
Sep 29, 2008 | Krell Home Theater Standard 7.1...
Krell kav300i, increasing volume by itself.
That is an extremely odd problem. I suggest finding a tech in your area who is familiar with the unit, or contacting krell directly.
Sep 21, 2008 | Krell KAV-300i 2-Channel Amplifier
Krell 250a power amp
Hi There WLAW,
Dec 26, 2007 | Krell Home Theater Standard 7.1...
145 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
