Question about Kicker Car Audio & Video
I have a 2001 Mustang GT, all I need is a diagram of the headunit wiring...everything is connected, but the subs aren't hitting.
Cerfer39
  • 709 Answers
SOURCE: wiring diagram
The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
The Octane R10 is a Single Voice Coil or SVC.
AMP+ to Sub+
Amp- to Sub -
Use 12 guage wire.
Posted on Nov 27, 2007
  • 273 Answers
SOURCE: all wires connected but no sound to sub
have you connected sub direct to rear speakers ? you need to connect direct to head unit for enough power or headunit to amp to sub dependant on wattage of the sub
Posted on May 15, 2009
  • 58 Answers
SOURCE: I need a radio mach
http://www.bullittarchive.com/7029.htm
Posted on May 03, 2011
Daveatwhips
  • 492 Answers
SOURCE: I'm trying to connect a
OK, you need to order the wiring harness for this. This will be a harness that plugs into your stock harness. The package that the harness comes in will have the wiring diagram on it. All radio wires are standardized, so it will be easy to hook the sony wires to the wiring harness because they will match. It will only cost a few bucks and will save you from frying your entire electrical system. Hope this helps.
Posted on Aug 22, 2011
iadame
  • 676 Answers
SOURCE: I need a color coded
iadame_35.jpgThis should help you out.
Posted on Sep 16, 2011
This stereo was installed into my 2001 mustang & there is no Bass
maybe there is a factory sub in this car or an amp of some kind. Did you connect the amp turn on wires in your ford harness. You'll need to basically connect all blue and/or blue-white stripe wires together to turn on a factory amp.
Sep 02, 2011 | Kenwood KDC348U
I'm trying to connect a sony cdx gt-400 harnes to a 1995 plymouth neon stock harnes but the sony wires aren't labeled
Aug 21, 2011 | Car Audio & Video
I have a pyle 12"
I am afraid in order to make use of your sub, you will need to buy an amplifier and a cabling kit to run it. You could run it straight from the headunit from one of the main channels but it would need a crossover so it wasn't fed any sounds which it couldn't cope with (high frequencies, they require very fast movement of the speaker cone, your sub wouldn't be able to do it)
Here is a link to a downloadable copy of headunit manul.
Hope this helps
May 09, 2011 | Pyle Car Audio & Video
Locate spark plugs on 2002 Ford Mustang GT, need diagram
Hi :) Here is the 2002 Ford Mustang GT wiring diagrams for sparkplug wires.
Mar 21, 2011 | 2002 Ford Mustang
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Need diagram of vacuum line that comes out of the back of the throttle body.a/c heater control.2001 mustang GT.
I have a 2001 mustang gt with ac i dont have air comming out of the front vents so i bought heater controls and no difference then i found a yellow vacume line off but cant find where it goes can any one help me !!!!!! thanks mary
Aug 08, 2010 | 2001 Ford Mustang
MY AMP TURNS ON BUT NO AUDIO OUTPUT TO MY SUBS! I HAVE A PLANET AUDIO AMP 1900 WATTS MONO.
First, test your sub terminals for an Open connection, or no resistance. This is to test if your sub is blown. This is usually the case.
Double check your wiring, not only to the sub, but from your headunit to your sub. Make sure your headunit is configured to work with your amp, if you have a setting for this (for instance, SUB: ON).
Jul 14, 2010 | Planet Audio AP3000D Car Amp
Firing Order for 2001 mustang gt 4.6 2v
The firing order is = 1-3-7-2-6-5-4-8
Jun 06, 2009 | 2001 Ford Mustang
All wires connected but no sound to sub
May 15, 2009 | Scosche Industries Scosche 05 Mustang...
Car Audio & Video Logo
21 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
