Question about Samsung ML 1440 Laser Printer
Samsung ML-1440 Print Problem
My ML-1440 LJ is skewing the printing so I end up with about 1/16" to 1/8" tapered margin width. Happens on both tray feed and manual feed. Any ideas?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
SOME PIECE OF PAPER ETC IS STUCK IN THE FUSING, PLEASE CLEAR THE SAME , PROBLEM SHOULD BE RESOLVED OMNIPRESENT
Posted on Oct 02, 2007
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
I cannot print from my Mac to a Samsung printer - and the Samsung web site does not have any printer drivers for this device on their web site. Any idea how to fix it?
Looks like that printer is not supported anymore. You can try downloading the driver for the newer model ML 1440 and see if that works:
ML 1440 drivers
Mar 01, 2011 | Samsung ML 1430 Laser Printer
LJ P3005, will not print from tray 2. Tray 2 is
Do a factory reset then reconfigure device one more time.
Jan 24, 2018 | HP LaserJet P3005n Printer
Samsung ML 2010 can't print in a certain format
you change office 2003 or its problem page setup
Aug 09, 2009 | Samsung ML 2010 Laser Printer
Samsung ml-1250 Printing stopped
Try purging the 3 pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Oct 21, 2008 | Samsung ML 1250 Laser Printer
Paper Jams and Margin Incorrect
Check the humidity of your paper, type and weight. Nothing more than 32# will run through the tray, any heavier should go through the bypass to prevent jamming. Margin follow the internal tutorial for moving your margins. Xerox machines do skew 3 degrees left for some reason or the rollars that feed from tray 2 need to be changed.
Peter
Apr 01, 2008 | Xerox Phaser 7750DN Laser Printer
Margin problem
Won't be the printer so I guess that leaves software or printer driver settings or the actual document setup.
Nov 17, 2007 | Samsung ML 2010 Laser Printer
Print is not straight
It sounds like the paper is being pulled into the printer at a crooked angle. Check that the guides in the paper supply tray are adjusted correctly to the paper width and are tight against the stack of paper. Alternatively one of the rubber pinch rollers that pull the paper though is slipping or worn smooth. Regards
Sep 24, 2007 | HP DeskJet 930c InkJet Printer
Samsung ML 1440 Laser Printer Logo
151 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
