Question about HP LaserJet P2015dn Printer
Printing problem with HP Laserjet P2015 printer
My Hp 2015 printer keep on displaying the "Paper Out Light Indicator" and I have loaded the paper tray with much sheet (A4-size) BUT the printer is refusing to print.I Even try to print a test page using the "GO button" but it refused to print.
I tried several attempts by restarting the printer and after restarting , the same Out of paper indicator will remain ON.
Can someone help me out?
  • knorton Mar 31, 2009
    I have noticed on a couple of our 2015s that you can add paper to the tray, but when you push the tray in, the release is not tripped that allows the paper to come up and conrtact the roller. You can tell this because the paper level indicator (little white thingamabob on front left of paper tray) stays at the top. For some unknown reason, elevating the front of the printer and then sliding the tray in seems to work. Until you get this to work, the paper out indicator light will stay on.
Posted on Jul 20, 2010
    An expert whose answer gotĀ voted for 100 times.
  • 87 Answers
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
Printing problem with HP Laserjet P2015 printer - mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input trayPrinting problem with HP Laserjet P2015 printer - mma01_13247_0 />
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only). Printing problem with HP Laserjet P2015 printer - mma01_13248_0igure 4: Opening automatic two-sided path door
5.Place the printPrinting problem with HP Laserjet P2015 printer - mma01_13249_0k surface with the front of the printer facing up.
Figure 5: Placement of printer
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
Printing problem with HP Laserjet P2015 printer - mma01_13252_0tp://" alt="mma01_13251_0" class="h_mi" />
8. Slide the pickup roller assembly to the right, and Printing problem with HP Laserjet P2015 printer - mma01_13253_0ft end cap.
Figure 8: Pickup roller assembly movement
9Printing problem with HP Laserjet P2015 printer - mma01_13254_0pickup roller.
Figure 9: Pickup roller
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the riPrinting problem with HP Laserjet P2015 printer - mma01_13255_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0 Printing problem with HP Laserjet P2015 printer - mma01_13257_013.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer Printing problem with HP Laserjet P2015 printer - mma01_13258_05.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartPrinting problem with HP Laserjet P2015 printer - mma01_13259_0> mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller aPrinting problem with HP Laserjet P2015 printer - mma01_13261_0n steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
Figure 17: Reinstalling the pickup roller
Posted on Nov 03, 2008
2 Suggested Answers
SOURCE: printing problem with HP 2015 Laserjet Printer
I was given this machine as a project and i need help pls,mail me o to read from you
Posted on Sep 13, 2011
HP M2727 paper starts to pick up and apparently jams just above the paper tray #2.,
It sounds like the pickup roller is not getting a good grab on the paper. When this happens the roller can not push the paper up into the printer where the next rollers can grab it. this is a very common issue after a year or two of use. The pickup rollers and separation pads come in a kit that is available on Amazon here:
Aug 21, 2013 | HP Laserjet M2727nf Multifunction Printer
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Apr 10, 2012 | HP LaserJet P2015dn Printer
On the top of the hp 2015 there is what looks like an 8 with like a sideways N next to it that keeps lighting up on my printer and inhibiting it from printing-- I don't have a manual to tell me what means.
Hello, The printer is indicating a Paper Jam.
Check the tray for proper paper loading, length and width. Check the rear exit, any paper back there? Check under the toner cartridge for loose papers.
1) Turn the printer off 2) Remove the main paper tray 3) look inside the hole in the printer from where the tray came out. You should see black rubber roller. paper dust can build up on this roller and cause the paper to slip. You can wipe this roller down with a water dampened lint free cloth, 4) Re-insert the tray, with paper in the tray. 6) Turn the power on to the printer. 7) Does the printer come ready? Print a test page.
For further information GOHERE
Feb 03, 2011 | HP LaserJet P2015 Printer
Hp laserjet 2015 printer shows an indicator light error that theres a paper jam but actually no paper jam or paper particles . I have cleaned aii the sensors and checked the paper path. Powers on well...
restart it
if problems insist check if sensors are working
if are working you need to replace motherboard
of your printer that cost to high
you better replace your printer
hope i had help you
Nov 26, 2010 | HP LaserJet P2015 Printer
Light with the triangle flashing - printer stopped
That means ATTENTION, you are either out of toner or have a paper jam.
Feb 18, 2010 | HP LaserJet P2015 Printer
HP laserjet P2015 is printing blank
Are you getting toner on the paper? To find out, print a test page. When you judge that the paper is under the toner cartridge, turn the printer off and look at the toner cartridge. Is your document displayed on the toner drum in toner? Is there toner on the paper?
No No Replace the toner cartridge. If that doesn't work you have more serious problems.
Yes No Replace the transfer roller.
Yes Yes If toner is smeared on the paper, replace the fuser.
Jan 08, 2010 | HP LaserJet P2015dn Printer
HP LaserJet P2014 keeps showing paper jam when there is no paper jam. How to clear?
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Jul 01, 2009 | HP Office Equipment & Supplies
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
5,819 people viewed this question
Ben Johnson
