Question about Jacuzzi Home
How do you remove the rotary knob for overflow drain for Jacuzzi tub
  • 123 Answers
SOURCE: what purpose does a jacuzzi rotary drain serve?
the rotary drain kit is just a drain kit that allows the user to open and close the drain via the rotary handle at the overflow..........it is mostly for aesthetics
Posted on Jul 31, 2009
  • 491 Answers
SOURCE: water leaking due to faulty knob on jacuzzi whirlpool
replace rubber wasers
Posted on Oct 10, 2009
uspartscente
  • 717 Answers
SOURCE: I just bought a foreclosure and it has a corner
any drain and overflow kit will fit that hole. it is a standard size hole for that item
Posted on Jan 12, 2011
heatman101
  • 43501 Answers
SOURCE: We have a Jacuzzi tub
Yes!!! You should be able to change those...
The first thing you will need to do is to find out the faucet manufacturer... then you can look for handles that will fit your faucet...if you can find the model number of the faucet it will make it even easier...
If you have a Delta, Moen, or other name brand fuacet the location of handles will be much easier...if it is a lesser know brand then the hunt could be much more difficult...
Do a search for like "delta faucet handles" and you will get a page like this
http://www.deltafaucet.com/customersupport/faq/Handles/index.html
Then you can check out what you need to do and where to go to buy those handles...
This should get your mind going...but probably will not answer all of your questions...
Feel free to comment back if you have more questions!!
heatman101
Posted on Jan 30, 2011
uspartscente
  • 717 Answers
SOURCE: The rotary knob that open
you would find that broken piece at your local jacuzzi whirlpool showroom. they will be the authorized dealership that will offer that part to you for sale.
the part you are looking for is part of the drain and overflow assembly.
Posted on Aug 18, 2011
Late 1980s jacuzzi tub
first you have to unscrew the tub show which is the piece on the floor of the tub where the water drains out. then get behind the front of the tub and you will see youre waste and overflow. at the bottom where the pipe goes to the tub shoe there is a slip nut that connects the pipe to a tee. unscrew the slip nut and pull out the pipe and there you go.
Jun 18, 2013 | Home
How to replace Lift Gate & Knob Diverter Tub Spout Kit
The lift gate as you call it is part of the overflow pipe and the drain pipe under the tub. Depending on the style you may have to remove the drain pipe behind the tub for access.
Jun 27, 2012 | Cars & Trucks
The rotary knob that open and closes the drain is broken .Need the broken part. My jacuzzi whirlpool is model:OPALIA . Color :white. The part is brass
Aug 18, 2011 | Jacuzzi Home
I can see outside of tub get wet and it leaks by the drain..its brand new..only does it when its drained after being filled to a high level..is it cracked or something? can't see any but dont know what...
If it only leaks when filled to a high level, the rubber washer behing the overflow plate is misaligned or missing. this plate is on the tub wall above the drain, and hld in in by 1 or 2 screws.
Oct 05, 2010 | Jacuzzi Home
Bath tub leaks
Well if its not from drain then it could be from one of the supply valve (hot/cold) it is also possible that its leaking from the overflow drain. this gets overlooked sometimes because of its location. One thinks that water has to be filled that high but one might be surprised how much water gets there when taking a shower or splashing in the tub. There should be an access panel to check the valves and overflow gasket. If not remove the handles and echuns to see if you can see anything.
Mar 31, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
How do you get hair out of a drain that is in a Jacuzzi. Can I unscrew the drain stopper or can I remove the chrome plate further up the tub?
unscrew what ever is covering the hole where the water drains out,.... use a pair of needle nose pliers or an old coat hanger with a little hook pre-bent in it (don't get it stuck in there) and pull out the hair,....it's that easy! good luck, cracklin joe
Jan 04, 2010 | Jacuzzi Rotary PVC Drain Kit DA34-815
I have a price fister BATH faucet set installed on an old bathtub> i would like to remove the knob that actuates the stopper mechanism. it is slightly triangular in shape and it does not seem to be a...
You will have to change out the waste and overflow. This is not a hard job, unscrew drain from tub, remove overflow plate and disconnect from p-trap. Go to local home improvement store and buy a new waste and overflow kit, many to choose from. Reinstall .
Oct 03, 2009 | Geberit Bath Waste and Overflow Tub Drain...
What purpose does a jacuzzi rotary drain serve? They only describe it as needed "for a smooth line." Seems expensive if it's just for appearance. Is it also a pump or grinder?
Jul 12, 2009 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Jets are draining my jaccuzzi tub
Check to see if there is an open valve where the water exits the tub. If there is a valve, shut it and your problem should be solved. good luck
Jan 15, 2009 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Home Logo
63 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
