When I turn the tv on, I get volume but the screen just flickers.
I also hear a clicking sound at the back of the tv panel. I tried unplugging it and replugging it after an hour... but that got me no where.
  • bonita_lolit
    bonita_lolit Feb 21, 2012
    The LED light is green when I turn it on.
Sounds like the "display panel" went out. The clicking sound you are hearing is the inverter attempting to make it work. Yikes! If under warranty try contacting manufacturer. If not, it might be less just to replace it. Hope this helps!
Posted on Feb 21, 2012
2 Suggested Answers
  • 8457 Answers
SOURCE: Samsung HCL4715W red light indicator is on, but TV does not work
Ur backlight video board is dead,must replaced.
Posted on Dec 10, 2009
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card, Lets first make sure your remote is not causing your problem, Look at the light (led) on the remote, is it lit and pulsing? If not you are having a problem with the control panel,  Have you recently cleaned your tv with a liquid? If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it.  Let me know if this helps and please rate this solution.   lone99star
Jan 11, 2009 | Soyo DYLT032D 32 in. LCD Television
Just a Black screen
needs a Y-Sustain board, about a 300 dollar part, unless you have a warinty, also try turning the tv on, after you get a green light, unplug the tv, after 15 seconds plug it back in, sometimes will make tv come back on
Jan 09, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
NO SOUND
Unplug the power to the tv for couple of minutes; replug and should have sound!
Jul 19, 2008 | RCA F32665 32" TV
My Sanyo HT28745 28" HDTV clicks but doesn't turn on
I have had a similar problem with my tv, it has something to do with the power supply.Try unplugging your tv from the AC outlet. While unplugged from the power supply hold down the - volume control and then plug the tv back in while holding down the - volume control. It should bring up the service screen. If the screen turns on and is blank then it may need to be brought in for repairs.
If the screen does turn on, either blank or with the service menu, turn off the tv and unplug it from the power supply again. With it still unplugged hold down the power button on the tv and then replug in the tv. continue to hold down the power button until the tv displays a video signal on screen.
Feb 02, 2008 | Sanyo HT28745 28" TV
Volume up then pic gone
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
