Question about NAD C542 CD Player
'No disc' Have not used the deck for a while and it's under a year old with relatively light use. Tried loading various CD's and all I get after about 20 secs is the message 'no disc'. The deck has not been moved and there is no obvious reason why this should happen. Any ideas?
Leave it unplugged for 5 minutes or so (not just turned off) to empty the cache. But i need an easy solution for the slipping.
Posted on Nov 22, 2009
    Novelist:
    Champion:
  • 275 Answers
Most likely a general service is required.As it is under warranty, take it iommediately to their Service Centre. They will clean the lens. grease the Drive Mechanism and Tray mechanism. Should - in all probability clear up the problem.
Posted on Aug 26, 2006
How to fix the ERR1 in Toyota Yaris CD Player
Error #1 means unreadable disc.
This condition appears a few reasons:
- Burned disc. These players don't always like burned CD's. Try burning your discs slower (like 8x instead of 40x, yes this makes a difference) or using higher quality CD-R's. Made in Japan discs are the best (Taiyo Yuden). Yes this also makes a difference.
- Dirty or scratched disc.
- Dirty Laser. I've had really good luck with those CD cleaners. It is a CD with some small brushes on the bottom. Worth a shot.
- Deck is plain junk.
Additionally, in this lnk could find other details about fix-error-1-cd-player.html
Hope this helps (remember to rate this answer ans send us your comments).
May 25, 2011 | Car Audio & Video
When a cd is inserted it displays 'no disc' and am unable to play the cd. I have tried several different cd's both new and old and same issue. CD player is almost 20 years old but if a simple problem to...
More than likely with a cd player that is as old as this one is the laser may have gone bad. If you can find a replacement laser component it can be replaced. Or it could be as simple as getting a cd player cleaning disc from just about any store and cleaning it.
Jan 06, 2011 | Sony Electronics - Others
Out of the blue, our 3-yr old single disc Bose Wave system has begun "Reading Disc" upon insertion of a CD (this is normal); but then returns a "Not Playable" error a few seconds later. It happens with...
This _might_ be caused by dust or dirt on the read lens of the CD player. The lens projects and reads a beam of light that is bounced off the surface of the CD surface to play the tracks.
Open the lid as if to load a CD. Remove any existing CD. Direct a short blast from a can of compressed air at the lens - or you could use a small artist's paint brush and gently wipe the surface of the lens to dislodge the dust, etc. Do not touch the lens with fingers. etc. as any oils will disrupt the light - and attract dirt and dust.
Load a CD and attempt to play.
Jul 03, 2010 | Bose Wave music system Multi-CD Changer...
The disk will not eject without fiddling it out i:e a scewdriver
Yes, but if you look on eBay, the optical drives are very expensive relative to buying an old machine and using it for parts.
Jun 02, 2010 | Sony MDS-JE440 Mini Disc Player
Disc play
Disk turntable motors will collect tarnish on armature contacts if not used for long periods. If you are experienced in electronics, I could walk you through a fix. If you are not, please take unit for service
Apr 24, 2008 | Sony CMT-BX1 Shelf System
No Disc
It could be some dirt & dust on laser lens. Did you try to clean it?
Oct 10, 2007 | Philips HTS3450 System
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Unit will not start or load disc
Try opening up unit and using canned air and blow it out - sometimes simple dirt causes things like this While inside glance and see if you don't have some old tape or bits of labels that have come off and are anywhere inside that might be hanging the various working areas. Try using cd cleaning disk and vhs cleaning tape Without seeing this not sure what is causing it but may be something simple like the dust or pieces of label causing problems or the little rubber "tires" and other rubber components having gotten stretched out and slipping.
Nov 05, 2006 | Emerson EWR20V4 DVD Recorder/VCR
No disc
Try using a cleaning disc, if that doesnt work take apart the unit and manually clean the lens. If that doesnt work your going to have to take the unit in for an estimate. If its more then two year old and you paid less then 150 bucks for it , it probably is not worth the estimate fee. good Luck
Aug 26, 2006 | NAD C542 CD Player
NAD C542 CD Player Logo
322 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
