Question about Sewing Machines
Serger blocked Needle won't advance after entering the machine. Hitting something solid but I can't see what.
  • Sewing Machines Master
  • 7,365 Answers
If it's hitting something solid, something is possibly broken or loose & also could be out of time
it needs to be checked at a sewing machine repair shop
Posted on Feb 21, 2012
  • 55 Answers
SOURCE: my janome harmony 9102D serger I think is out of
i suggest you get a tech to re-time your machine. timing is complex on an overlocker and if not done correctly you will probably break a looper.
scott.
Posted on Jul 27, 2009
javeedcare
  • 316 Answers
SOURCE: needle won't line up. keeps
THE PROBLEM SHOULD BE WITH THE ALIGNMENT OF THE NEEDLE CARRIER IF THE NEEDLE IS FIXED CORRECTLY, GET A TEC. TO FIX IT.
REGARDS
Posted on Jul 03, 2011
bargainbox
  • 1388 Answers
SOURCE: Janome Needle plate and needles hitting something underneath
The broken pins are called chaining pins and are tricky for the home user to replace without risking damage to the needle plate as they are difficult to remove and the tiny burr used to hold them firm can easily open up and no longer grip the pin.
There are only a couple of things under the needleplate that are likely to collide with the needles. 1. Lower looper - with the needles 2. Both Loopers colliding with each other - not with the needles 3. Needle guards attached to lower looper - with the needles 4. Fixed Needle guard - with the needles
If you remove the needleplate and VERY gently turn the handwheel you should be able to see and feel where the collision is occuring and have a better idea of the issue.
I would strongly advise that you do not try to operate the machine until you are sure that the colliding components are adjusted. Broken loopers are approx $65 AUD and guards, tho' only about $20 AUD require some finesse in adjustment. Chain Pins approx $6 AUD
My recommendation is to speak with your local Janome dealer for advice and an approximate price to repair, replace or adjust as the case may be.
Your country's Janome website is certain to have a Dealer Locator page to list the nearest to you.
This is one occasion where it is sensible to call on the people who do these things routinely rather than try to DIY and make a more expensive hash of it.
www.bargainbox.com.au
Posted on Nov 22, 2008
  • 1702 Answers
SOURCE: My serger won't start. Motor is running but
Hi, On most of these newer machines they have a clutch that you engage to fill the bobins.
Please make sure that the clutch is disengaged for normal use. If this is all OK see that belt
is attached on motor.
Posted on Jun 05, 2011
  • 1833 Answers
SOURCE: I have a Brother SE-270D
The bobbin case may not be correctly installed and iscausing the misalignment and breakage.
Look through the maintenance section for cleaning and lubricating. This willalso provide info and a picture for setting the bobbin case back into theshuttle.
No manual? Singer and Brother have free downloads at their Internet sites.Other brands are iffy as to being able to download without paying.
If you do not have (or cannot obtain) a manual, raise the needle to its highestposition and this will align the shuttle race for the bobbin case. There shouldbe a groove in the side of the race for the arm/wing on the bobbin case to fitinto.
If cleaning the area below the needle plate and bobbin area along with correctinsertion of the bobbin into the bobbin case and the bobbin case into theshuttle do not solve the problem, then you have a bigger issue - the timing andneeds to be adjusted (not for a novice) and requires a trip to the shop forserviced. If that doesn't work, change your needle plate.
If you've been using a straight stitch needle plate (a plate with a small hole,often used for sewing fine, delicate fabrics), switch to a needle plate with awider hole.
Hope this will help you. Good Luck.
Posted on Jul 26, 2011
Right hand needle keeps breaking
I'm assuming your taking about a serger, so here are my suggestions
check your tensions
make sure your using the right needle for the machine and fabric
make sure the needle is inserted correctly into the needle holder
Finally, take the thread out of the needles, open the front covers and move the hand wheel slowly toward you. Check to see if you hear a clicking sound. If you do it could means your machine is out of time (the needle is hitting something) and this will create the problem.
Mar 14, 2016 | Sewing Machines
Singer serger 14u
Sounds like your needle is hitting the needle plate instead of going through the tiny hole down to the bobbin. Try using the handwheel slowly and watch. Or perhaps the needle is hitting the bobbin case. Something has been knocked off the straight I think. Has your machine been dropped or dmamaged?
Oct 15, 2013 | Sewing Machines
Needle hitting the shuttle
since you were sewing harder material it's possible that the
machine jumped time & needs to be checked at a sewing machine
shop
but try putting in a new needle first
if it still is hitting the shuttle then it needs to be checked.
Oct 16, 2012 | Singer Sewing Machines
White Superlock serger continually breaking needles
First take all the thread out of the machine. Put in new needles and run the machine slowly by hand and see if there is a problem with timing. If the needle hits and bends or breaks... take it in to be timed. If the needle don't hit....
Make sure you are properly threading this thing. Unlike a sewing machine which gives you some leeway, Sergers must be threaded in a certain order. Typically, upper looper, lower looper, right needle left needle. If you break a thread you can't just rethread that thread... you have to start from the beginning.
You might check singerco.com for the manual for this thing. They have most of white's manuals online they are identified by a W before the serger model number.
Oct 04, 2012 | White Sewing Superlock 1934D Mechanical...
My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
May 03, 2012 | Singer Sewing Machines
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
Sewing machine wont stitch in reverse, needle hitting bobbin feed.
since the needle is hitting the bobbin feed it has to be replaced, if the machine continues to hit the bobbin feed the most likely the machine is out of time & has to be retimed at a sewing machine repair shop
they would also be able to see why the machine won't stitch in reverse
Mar 31, 2012 | Brother XR-65t Mechanical Sewing Machine
My needle keeps breaking. So I unthreaded everything and cleaned the bobbin area. Per the manual i rethreaded everything but when i get to the part of turning the balance when toward me until the needle...
check to make sure the needle is inserted correctly--flat side to the back of the machine
that the needle is inserted all the way up in the needle shaft
check the needle clamp screw to make sure it's not loose
is the needle correct for the fabric that's being sewn
check to make sure the needle is not hitting the needle plate- if it's hitting the needle plate or the bobbin case then it's possible the machine is out of time & would have to be serviced because they have the proper tools to time it
Aug 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
I volunteer at a women's prison in their sewing class and we have model 385-16231301. The bobbin thread does not pick up. The bobin case seems to sit in their properly, but when I turn it manually...
check the needle to make sure that it's inserted correctly, the flat side of the needle goes to the back of the machine,, and make sure the needle goes all the way up into the needle cavity .
make sure the bobbin is correctly inserted
clean under the needle plate area & in bobbin area for loose threads or lint
if none of the above work & the needle is still hitting something then it 's a great possibility it's out of time & needs to be serviced, cause the needle should not be hitting anything when it goes down.
Aug 26, 2011 | Kenmore Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
