Question about JVC LT-42X579 42 in. LCD TV
My tv shown no pict just a blue screen - JVC LT-42X579 42 in. LCD TV
I can't tell you exactly what is wrong with it without more detail but usually that means there is no signal coming to your tv from your input device. Try to change the cable from your video input device.
Posted on Feb 21, 2012
My TV rca model hd52w68 HV black in white Pict
I think you were trying to say you have a black and white picture(?) Make sure you haven't connected a composite(yellow) video source to a component (red/blue/green) connection on the TV.(If you connect a composite video to the green component connector,it will appear to be in black and white).
Jun 09, 2014 | Televison & Video
The green light comes on but no picture..
do you have check th baterry if no pleas check the battery
Jul 16, 2017 | Televison & Video
The 32inch flat screen tv has sound but no picture the screen turns blue
If the TV is still under warranty return it ASAP. The set will need to be serviced
Oct 22, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I plugged in the pc with a dvi cable but no pict is showing,in the front pc connection the pict shows but the picture is rather 4:3 or full screen but very bad pict(changing the resolution on the pc)telll...
When you connect the DVI, try hitting the input, source, or conection button on the remote on TV. Some vendors use different names for the button. Use the procedure below to set the resolution for the second screen to 640X480 first, then move the resolution up one notch at a time to see what your TV can handle.
Many televisions don't allow an input through the VGA connector that's a higher resolution than 640X480. That is probably the format that you see appearing on screen where everything looks huge. You may be able to increase from that slightly after getting 640X480 working.
When you've made all the cable connections right-click on the desktop, then choose PROPERTIES from the bottom of the list.
A small window will appear with a few tabs on the top choose the last one, SETTINGS.
Click on the screen shown on this tab with a numeral 2 shown. On the middle-left you'll see a slider showing large and smaller at each end, bring it down to 640X480, then hit apply
A pop-up will appear asking you to confirm that this size is working, click yes if when it does.
Try increasing the resolution by a notch to see if the next size up works with your TV. If you see the Invalid Format on your TV again, you've gone higher than this particular input on your TV will accept.
To get a higher resolution signal you made need to switch to a different cable type, try DVI or HDMI. Either of the two should work more automatically than the VGA cable you are now trying.
If your computer only has a DVI port and the TV has an HDMI port you can get a cable that has DVI at one end and HDMI at the other by clicking here:
May 11, 2011 | Televison & Video
Tv powers up have sound no picture erea 40 lcd
sounds like shorted crt  if your handy open fire up carfully tap neck ofcrt may restore pict
Dec 01, 2008 | Televison & Video
19 in blue screen only sound works great
blue screen is the noise mute screen. however the audio is not getting muted and hence the buzzing....meaning the tuner on the TV is not getting locked on to the station/frequency
1. check your antenna if you are using one. Autotune
OR
2. Reconnect coax from the cable box to Tv and autotune.
OR
3.Use the Video out from the cable box and connect it to one of the video inputs on the TV. Switch your Tv to that component. Use the cable box to change channels (Best case scenerio)
Feb 28, 2008 | Westinghouse SK-26H240S Television
un plug the tv for 3 minutes to reset it, then plug it back in. if this dont fix it, please get back with me and tell me if you had any power outtages or surges. some times lightning strikes can burn out the tuner when it strikes the cable line.
Oct 19, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Sony proj tv,sound,green pict few seconds then shuts down
could be three different things.
1. could be the crt itself as a tube with dfective phosphure wil do this
2. could be the vertical ic on the crt board
3. could be the focus pac.  located in front of tv with 6 adjustment knobs on it.
Oct 06, 2007 | Sony KP-41T65 41" Rear Projection...
Toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Jun 28, 2006 | Toshiba 42H83 42" Rear Projection...
JVC LT-42X579 42 in. LCD TV Logo
198 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
