Question about British Telecom Synergy 2110 Cordless Phone
Loosing Signal I have bought a second hand system from ebay. At first the phone worked brilliantly but without the answerphone switched on. When I activated the answer phone I found the signal would be lost and the phone would spend days searching. I have switched off the answer phone service which corrected the problem for a while however, it has returned. The phone will charge fully. When the phone searches for a signal it will also charge all handsets at the same time. Is it simply new batteries for all handsets? Or something blocking the signal? It is not the telephone line as I kept a phone plugged into a point and this works while the BT phone doesn't. Please advise. Helen
  • Anonymous Mar 17, 2014
    I can't turn the answerphone off and don't know how to access my messages.
  • 59 Answers
How many extensions do you have ? and do you have broadband (adsl) ? sometime's this could be just down to the phone line - if you have broadband (adsl) there has to be a filter pluged in on all other extensions, do know i'm guessing let me know this could be your problem as the filter is blocking the signal or interfering.
Posted on Apr 08, 2007
My main phone sitting on answerphone base is permanently 'engaged' therefore unusable. Second phone working fine as is answerphone. Please help?e
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
It also might help if you could specify the make and model of your phone.
Thank you for using FixYa.
Nov 28, 2011 | Lands Phones
Hello, i am from serbia and i have a nokia 8801 mobile phone. my question is can i somehow make it work on our networks without loosing the signal sometimes. does this phone has the option to change the...
Your phone is gsm and there is no gsm/cdma option that you will need to switch. Losing signal has to do with tower issue or an internal antenna issue. That phone is built with aluminum and it does have issue with signal.
Oct 30, 2010 | Nokia 8801 Cellular Phone
Want to enable answerphone
if you wanna to answer your phone call just press the green button. if you can't do that just put your phone to auto answer after certain seconds or minutes of ringing.
vote me! if it works for you
May 13, 2010 | Sony Ericsson K800i Cellular Phone
Nokia 1112 has no signal. Is this fixable?
hi... since u brought ur mobile n other country an using it n other country th service providers for country may differ.. so u jus go th authorised service centre an ask to mak ur mobile to work n th country u r staying....
Jul 01, 2009 | Nokia 1112 Cellular Phone
We have an se445 cordless phone/answerphone. with answerphone on, the line rings 4 times then stops briefly before continuing to ring instead of cutting onto answerphone. BT line has been checked and gain...
Regarding the Philips SE445 cordless phone/answerphone. I posted my problem where it rings 4 times then continues to ring without cutting into the answerphone. My phone is now fixed and working as it should which is great. I was unable to make calls because I had no dial tone and although Virgin checked my line and said it was fine, it obviously wasn't. The problem was with the line in the Exchange Box - the big green boxes that are located on the roadside - the line was broken there. Once fixed, I had my dial tone and the SE445 is working perfectly. To nomad1066, I would insist that BT check their Exchange Boxes as this is probably where the problem lies. Check whether you have a dial tone. Hope this helps.
Jul 24, 2008 | Lands Phones
No ring on phone
check that you have master type socket
Jun 02, 2008 | Lands Phones
No signal
3100 Network Problem
Apr 16, 2008 | Nokia 3100
Philips Kala 6523 Cordless Phone
hi, do you have instruction manual i cant find mine. i have been using an other phone and gone back to this one but need to change answer machine message can you hlep please. patem
Feb 09, 2008 | Philips Kala 6523 Cordless Phone
Online manual
Hi - took me ages to work out without the manual, but when you're in the answerphone menu (described above), press 9 (record OGM) then either 1 or 2 (1 for OGM 1 and 2 for OGM2), speak your message, then press 5 (stop), the message will automatically replay, then you're sorted
BRIAN
Dec 27, 2007 | Lands Phones
Answerphone Motorola V3
Go into setting, then into diverts, then into voice calls, choose diverts then down to off, you can switch it off or on but not adjust the time it runs
Nov 12, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
British Telecom Synergy 2110 Cordless Phone Logo
129 people viewed this question
Top British Telecom Lands Phones Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
