Question about Dryers
We want to purchase a replacement door for our simpson maxidry 457, 4.5 kg heavy duty clothes dryer
    Genius:
  • 1,122 Answers
Go to sears .com click on parts out in your model number and they should have what you need,or go to repair clinic .com and do the same-mike
Posted on Oct 27, 2008
  • MIKE major Oct 28, 2008
    that was a fixya answer all the way!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
MY SIMPSON MAXIDRY 362 3.5KG HEAVY DUTY DRYER KEEPS OVERHEATING AND CUTTING OUT. WHEN IT STOPS AND I PRESS THE SAFETY SWITCH IT TURNS ON AGAIN BUT ONLY FOR 10 MINUTES. CAN YOU ADVICE ME ON WHAT I CAN DO...
I would check the exhaust pipe outside and make sure it is not blocked and has good strong air flow while the dryer is running. If there is not good airflow, then clean out the exhaust hose and pipe. There could be other problems, but I would start with this.
May 01, 2010 | Dryers
Broken door on simpson maxidry 362
when it comes to whitegoods old is good. your dryer will outlast most new ones. buy the new parts it will b lot cheaper than a new dryer. not much goes wrong with the old simpsons. please reply if u need more help
Apr 11, 2010 | Dryers
Simpson Maxidry 457 not heating
Check thermal cut outs/ Element Should read around 32 ohms on a multimeter if its ok...
Apr 09, 2010 | Dryers
I need a hindge for my Simpson Maxidry 361 clothes dryer
You could Purchase it from :-
http://spares.alliedappliance.com.au/catalogue/catalogue_4_4_6_73_0ca48000.html
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 08, 2010 | Dryers
Hi i need to fix the belt that rotates the dryer
MOST SERVICE COMPANIES WILL HAVE A BELT, OR RING SIMPSON ON 131350
BEFORE YOU FIT THE BELT MAKE SURE THE CENTRE PULLY IT GOES ON SPINS FREELY- IF ITS TIGHT IT WILL RUIN THE NEW BELT.
Jul 06, 2009 | Dryers
I have a simpson maxidry 326 dryer. It cuts out and stops tumbling after 5-10 minutes,it seems to cool right down and then I have to start it again. So if for instance I put it on the hot setting and say...
Check if the drier is blowing out air from the air duct. If not, the fan pulley is likely broken. With no way to cool the machine the thermostat will be shutting the machine off as it overheats.
Sep 03, 2008 | Dryers
Dryers Logo
152 people viewed this question
Top Dryers Experts
