Question about Coby MP977 Digital Media Player
Coby mp977 hdmi no out put to tv
Hdmi out and hdmi to componet out tv just say not suported
How can I tell if it works without power cord
Make sure your using the front facing camera and connected to wifi
Jul 24, 2014 | Coby MP977 V-ZON 4GB Portable Media Player...
I connected my dvd player to my coby hd tv, and the movie still want play, maybe I have it on the wrong chanel. What chanel should the hd tv be on?
Are you using a HDMI cable? Push the SOURCE button & select the corresponding HDMI input with the HDMI input from your DVD player. The HDMI inputs on the tv should be numbered & you can then select the correct number HDMI on the source screen. Good luck.
Sep 02, 2013 | CobyElectronics Coby Electronics Coby...
How to connect laptop to my coby tv?
Check if you have an HDMI or VGA/DVI port in your LCD TV and LAPTOP. Once you have those ports you can just buy an HDMI cable or VGA/DVI cable to plug it to your laptop.
Jan 31, 2011 | Coby TFTV2225 22 in LCD TV
Cant get my Coby DVD288 to play with HDMI cable.What settings do I need to change?
Can you please tell me how you have it setup to the TV? HDMI output on the DVD288 to HDMI input of the TV? Make and model number of the TV will help me to do more research.
Jan 14, 2011 | Coby Televison & Video
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Hi I am Tom. I have a new Coby TFDVD2274 22
Tom for your HDMI problem try hooking up separate audio cables to your tv if you get audio you probably need to change those hdmi cables.
Oct 16, 2009 | Coby TF TV1524 15 in. LCD TV
Ps3 no picture or sound on tv
If your using a hdmi cable it maybe set to componet if your using componet it maybe set to hdmi. The only way to tell is to connect both ways to see which one works.To change these options it will be in the settings option. If this is not the problem you can call sony and send them your ps3 and alot of times they will fix the issues for free.
Jul 05, 2009 | Sony Video Game Consoles & Games
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Coby MP977 Digital Media Player Logo
85 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
