Question about Cell Phones
Seven stars K800 red laser
Need to replace the red laser. Any ideas?
What is the color code for a red xj650 1982
the color for 82 is called star red -- 00h8 -- STR ----star red
Find the color code of your Yamaha Motorcycle
Dec 03, 2016 | Cars & Trucks
Reset password samsung sgh g600
The only way to get rid of it, is to reset it. Samsung g600 has an Full reset code. look it up. Instead of giving the code,start the emergency call, and give it the code. The default factory-set code should be 1234 or 0000.
Jul 11, 2013 | Cell Phones
Clear memory for the fax machine panasonic uf490
Hi
Right!!!
Press 'Function' then 7
Press 'Monitor' seven times
Press '*' (star)then 0
This Gets you into service mode.Scroll down on using Large Round Button until you get one that says Ram Initialize press Start then Scroll down unitil you see All job Clear,then press start again,M/c will reboot and this should clear your memory.
Powerdown once then your memory% should disapear
Good Luck!!
Sep 21, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
Trying to charge my sony ericsson k800 mobile and it won't charge. Cannot get 'optimised charging' to appear. Battery now completely flat
Hi, you will need to get another charger. Charger might be faulty and will need to be replaced.
If after replacing charger and still does not charge, then the charging port where you plug in the charger is damaged and needs to be replaced.
Take care.
May 20, 2010 | Cell Phones
Key pad locked on k800 sony erricsson
press menu button and star when unlocked go in to settings and change it
Aug 14, 2009 | Cell Phones
PS2 Slim Silv won't turn on laser or move, disk no move...HELP..
When you replaced the laser, did you remove the shorting solder connection? These lasers are shorted to prevent static electricity from damaging the optics. There is an area on the optics that has a solder bridge that needs to be removed for proper operation. Check that first.
Let me know if you need anything else.
Dan
Feb 25, 2009 | Sony PlayStation 2 (PS2) Console
Sing star goes all fuzzy
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER CALL FELTON (870) 733-1375 OR EMAIL ME IWHYOU@YAHOO.COM
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
Dvd reading
I had the same thing happen to a used DuraBrand 7" Portable DVD Player. Check and see if the laser transport is locked in at the top of the track -- which would be in position to read the outer edge of the DVD. The laser transport gets locked into this position and you get "no disc" error messages.
I removed the bottom of the DVD player -- a matter of seven screws -- and moved the laser transport by hand nearer to the center post of the DVD turntable. This cured the problem and my DuraBrand is working fine now.
I have no idea what makes the laser transport move to the extreme outer position and get locked there, but this solution works. Good luck with your own.
Jun 25, 2008 | Durabrand DUR7 Portable DVD Player
IRda thing of doom
Try leaving the battery out overnight. Then put it back and try to turn on.
May 22, 2008 | Sony Ericsson K800i Cellular Phone
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
