Question about iLO 3200 32 in. LCD Television
Seven stars K800 red laser
Need to replace the red laser. Any ideas would be helpful
Reset password samsung sgh g600
The only way to get rid of it, is to reset it. Samsung g600 has an Full reset code. look it up. Instead of giving the code,start the emergency call, and give it the code. The default factory-set code should be 1234 or 0000.
Jul 11, 2013 | Cell Phones
Trying to charge my sony ericsson k800 mobile and it won't charge. Cannot get 'optimised charging' to appear. Battery now completely flat
Hi, you will need to get another charger. Charger might be faulty and will need to be replaced.
If after replacing charger and still does not charge, then the charging port where you plug in the charger is damaged and needs to be replaced.
Take care.
May 20, 2010 | Cell Phones
Key pad locked on k800 sony erricsson
press menu button and star when unlocked go in to settings and change it
Aug 14, 2009 | Cell Phones
PS2 Slim Silv won't turn on laser or move, disk no move...HELP..
When you replaced the laser, did you remove the shorting solder connection? These lasers are shorted to prevent static electricity from damaging the optics. There is an area on the optics that has a solder bridge that needs to be removed for proper operation. Check that first.
Let me know if you need anything else.
Dan
Feb 25, 2009 | Sony PlayStation 2 (PS2) Console
Sing star goes all fuzzy
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER CALL FELTON (870) 733-1375 OR EMAIL ME IWHYOU@YAHOO.COM
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
Dvd reading
I had the same thing happen to a used DuraBrand 7" Portable DVD Player. Check and see if the laser transport is locked in at the top of the track -- which would be in position to read the outer edge of the DVD. The laser transport gets locked into this position and you get "no disc" error messages.
I removed the bottom of the DVD player -- a matter of seven screws -- and moved the laser transport by hand nearer to the center post of the DVD turntable. This cured the problem and my DuraBrand is working fine now.
I have no idea what makes the laser transport move to the extreme outer position and get locked there, but this solution works. Good luck with your own.
Jun 25, 2008 | Durabrand DUR7 Portable DVD Player
IRda thing of doom
Try leaving the battery out overnight. Then put it back and try to turn on.
May 22, 2008 | Sony Ericsson K800i Cellular Phone
LG Chocolate Pink K800
It sounds a bit like an infra red icon but I don't really know. Go to connectivity and infra red and turn infra red off. Hope this helps
Jul 30, 2007 | LG CHOCOLATE VX8500 Cellular Phone
iLO 3200 32 in. LCD Television Logo
160 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
