Question about LG Televison & Video
I have a sony lcd tv it's been 2 year's now that i have purchased it.in the middle of the screen there is a straight line,on the top of screen it is clear picture and on the bottom half its al
techman
  • 3130 Answers
SOURCE: SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Posted on Mar 25, 2006
techman
  • 3130 Answers
SOURCE: Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 22, 2006
  • 556 Answers
SOURCE: can only see half the picture
your problem is in vertical output section.
the ckt which is connected to vertical output section is called feedback ckt.
please check.
1 loose contact in feed back ckt.
2 mostly this problem is due to electrolytic capacitor failure.
3 vertical output  IC or transistor failure.
4 check for proper supply to vertical output.
5  low value resistor failure in v/output ckt  (.in rare case)
IF YOU ARE NOT TECH PERSON PLEASE TAKE HELP.
  1. hope this will help.
Posted on Oct 10, 2007
  • 1030 Answers
SOURCE: RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Posted on Dec 07, 2007
  • 1030 Answers
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
My sony bravia 32" is
hi ;
there's a problem in screen driver of your LCD, if you lost your receipt,that's bad luck.
if you know how to disassemble the back case of the TV , you can try some RESETTING of connectors from LCD screen driver to display driver board
its only 50% chance to remove the line.
thanks.....
Sep 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
My sony laptop vaio cs vgn-cs36's lcd got a straight line on bottom of the screen. what should i do to fix those line? because the line is getting worst now. help me! i bought it last year oct but...
That sounds like you require a new/replacement screen.
Check your date of purchase with a warranty repair in mind.
Do it quickly as it may still be covered.
Jan 08, 2011 | Sony VAIO Notebook
Line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
Nov 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
There is a black line straight down the middle of the picture. Is there an adjustment for that? The Tv is only a little over a year old.
sounds like you have a deffective segment in the screen. if it's still under waranty see if you can have the tv replaced with a refurbished model.
May 31, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Failing lcd(s) in middle of screen from top to bottom
Most likely the panel is bad. You have a year warranty on the panel. Please check your purchase date and contact a local Sony authorized repair facility.
Apr 15, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KDL 40S20L1
You should have a 1 year warranty from Sony. Call them before it expires. This is probably a LCD panel issue.
Oct 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lines in the middle of screen
Fixed.  The problem was the B board (digital signal processor). Bring lots of money.
Dec 19, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
35 people viewed this question
Computer Repairing
Computer Repairing
