Question about E-Machines eMachines Desktop PC
My usb ports no longer work
I cant get my cameras ( 3) to connect to my pc. It says that the usb ports arent working
Try to update the driver and it should solve the problem. (right click on my computer, go to properties and then click on device manager. Now, in the device manger look for the USB controllers. And again right click and see if you can update driver software)
good luck
Posted on Feb 20, 2012
Cant see my android on pc when connecting a usb cable
You can open "settings" on your phone and click "developer options" and click "USB debugging" under the "Debugging" options.
Also, I found Amazing Way to Connect Android to PC Mac Windows recently:
1)Download and install "Airmore" and then open it.
2)Visit "airmore.net" on PC and click "scan to connect" on the phone to scan the code. Remember the PC and phone must under the same wifi.
3)Click "accept" on your phone
4)Transfer files between PC and android.
Actually I also transfer contacts, manage apps and SD card on PC.
Sep 18, 2015 | Android Cell Phones
My usb port on monitor isn't working. how can i fix this?
The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
Apr 13, 2012 | NEC MultiSync 1770NX 17" LCD Monitor
Cant transfer photos from camera connecting as instructed in book bot nothing happens
To transfer Pictures to PC only connect to PC using USB Cable.
If don`t work try the following
1.- Go to control panel -- Device manager
check if they are a yellow mark near the device
if have a yellow mark, select -- right click --Uninstall
2.- restart your PC and check if work
If trouble continue
1.- Try connect to other USB port
2.- Connect to another PC
3.- Try with other cable
You can buy USB Cable on
http://www.ebay.com/itm/USB-Cable-U-8-Kodak-Easyshare-C310-C330-C340-C360-/140526859630?pt=Camera_Cables_Cords&hash=item20b80db56e
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Kodak EasyShare C340 Digital Camera
I cannot connect my camera to my pc
At first connect your camera through USB port and install your Driver for your camera. Now you are able to connect camera with your pc
May 09, 2011 | Samsung Vimicro USB2.0 UVC PC Camera
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
Samsung s630
First, I need to ask the dumb questions:
1. Are both computers running XP?
2. When you connect the camera, do you turn the camera on?
3. Do other USB devices work when connected to the same
USB PORTS you are using to connect the camera?
Ok, since the camera is not recognized at all on both computers, we can pretty much disregard USB PORT failure, but just in case, try different USB PORTS on both, please.
Most if not all cameras should be recognized as mass storage devices just by connecting them to USB PORT on computer, and should be visible as a new drive in MY COMPUTER icon.
Maybe your bundled USB CABLE is not working, or this is one camera that insists on using the bunbled software package that came with the camera.
Last thing to try is to buy a multi-card reader/writer and put the memory card in there. That has to work!
Hope that helps.
Dec 30, 2008 | Samsung Digimax S630 Digital Camera
I cant connect my psp to my pc
try using another cord(either buy a new one or borrow someones) to connect your psp to your pc and also try plugging in something else to the computer with the same hookups to make sure its not your computer ports. if niether of those suggestions work, you might have a problem with the ports on your psp being shot, which is a problem with alot of electronics. also make sure that the ports arent plugged or gummed up with anything and look if there is any wear on the contacts of the wire and the ports.
Oct 14, 2008 | Sony PlayStation Portable (PSP) Console
Touch pad and usb ports
did u install mother board drivers /not ? install M.bord drivers.
chk all usb ports are connected to mother board.
if problem persists go to decice manager expand USB then right click on usb driver select uninstall.
right click on usb select scan for hard ware changes .system will install that drivers automatically.
Aug 04, 2008 | Computers & Internet
PC shows no disc in drive E
is this because i used the usb cable for another devide?
- i dont think so. the usb cable that comes with the benQ camera is the usual usb cable. i used it for other devices and still works fine with my camera again. i even used another usb cable from other devices in camera and it works fine.
is it a virus maybe?
- well you can try inserting a different device in that usb port, now if it still cant see it, its probably busted. all your usb ports are on used? wow! how about you try taking some of it out and check those ports for your camera.
Nov 26, 2007 | BenQ DC3410 Digital Camera
ClickSmart 510 Will Not Be Turned On
make sure the terminals the batterys go into arent dirty, thats usually one of the main reasons a camera wont function. hopefully it works out, good luck
Aug 23, 2007 | Logitech ClickSmart 510 Digital Camera
E-Machines eMachines Desktop PC Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
