Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
Kenwood dishwasher We just went to turn it on and the display reads "E4", beeps about 10 times, and there seems to be no way to get past this, rendering the dishwasher useless
    Problem Solver:
  • 16 Answers
E4 means overfilled which in practice means there is water in the tray at the bottom of the machine. Lean the machine forwards and the water will drain out and clear the fault code. chances are it will fill up again so if it repeats the leak will need to be found.
Posted on Jan 24, 2010
  • rory166 Jan 24, 2010
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
My Kenwood Dishwasher shows an E4 error code
Howdy:) An E4 or E5 error indicate an abnormal water level which means too much inlet water. Here is the shortcut to the Kenwood PDF file with the user's manuals.
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
You can cut and paste it into your browser's address window. Your model was not indicated in your message, but the error codes are standard throughout the Kenwood models. I hope you find this useful:)
Aug 25, 2010 | Microwave Ovens
What men cod e4 on dishwosher kenwood kdw12st3a
Hi
Error e4 on Kenmore usually occurs when there is drain clogging or due to debris stuck in the bottom of the dishwasher. Drain out the excess water from the dishwasher, now remove the mesh and the filter. Now, check and remove any food material or debris stuck. Now pour 1-2 litres of luke warm water and let this water drain. After this replace the parts and run the dishwasher on eco mode without any tablets or soap. Try this 2-3 times and then reset the dishwasher by unplugging it for 5-10 minutes.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Kenmore 15762 Dishwasher
Kenwood kdw243a
The dishwasher still has water in it.  Lean dishwasher back at least 45 degrees and water should drain out through overflow pipe.  It could be caused by the dishwasher not being level.  Otherwise from reading reviews online it seems to be a common fault with this dishwasher and lots of people have returned and purchased different.
Sep 28, 2008 | Dishwashers
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
I HAVE A KENWOOD KDW12ST3A DISHWASHER AND IT HAS THE E4 ERROR CODE THEY DID NOT GIVE ME A MANUAL WITH IT CAN YOU HELP
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Apr 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Kenwood dishwasher kdw8st2a
I had E4. Initially couldn't get it to clear.
In desperation, switched it off, turned it on it side and drained it onto the floor.
The E4 disappeared and the dishwasher is working normally.
Jan 22, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
153 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
