Question about Memup Kobalt USB 2.0 external double layer DVD writer (502207) CD-RW Burner
Memup exteral multi media hard drive I/O device error
I have had my multi media player for 6 months and have been transfering films onto it and watching them via the TV. Everything was working fine until I tried to save a file and I/O device error appeared half way through transferring a file. When I plug the hard drive into the computer, the computer slows down and I cannot acess the E drive. When I plug it into the TV it is also very slow and does not show the films that are on the hard drive. I have tried running a scan on the E drive but cannot acess the drive at all through my PC. Any solutions??
What are the step by step instructions for transferring photos from my computer to my passport essential se. my computer has windows xp
Hi Welcome to FixYa!
Just simply follow the steps for you to be able to transfer files from your computer into your external hdd.
1)Right Click on the folder where your photos are located.
2)Click Send to, then select the appropriate drive for your passport essential.
3)It will now copy those files onto your external hard drive which is the Passport Essential.
Hope this could be a big help!
Jun 27, 2011 | Western Digital My Passport Essential SE...
How to restore a zen xfi2 when mistakenly formatted through computer?There are no more files on the player and an error window that reads Media is not formatted with a supported file system
a usual message for every format performed.
1. log onto the microsoft network site to acquire a digital media restore software or verify from the ZEN network site for restore software programs also.
2. once dowloaded onto a computer, connect the ZEN device with a USB cable provided should establish a transfer of software copies back into the Device.
3. A restore of the device with default ZEN software would require transfering media once more.
4. download onto a computer the a media converter software
5. compile media to be tranfered into the ZEN device
Dec 25, 2010 | Creative Technology ZEN XFi2 Digital Media...
My computer wont recognize my USB
Try the following steps:
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
If that doesn't work, then you may download and install the Sansa Firmware Updater and update to the latest firmware.
Jun 04, 2009 | SanDisk Sansa e260 MP3 Player
Disc Read Error Sony DVD Handycam
Does your camera have other outputs, i.e., composite-video and L/R audio ?
If the disk "plays" inside your video-camera, then use a "video-capture" USB device, to "play" the movie into the USB device, and "record" from the USB device into your computer.
May 31, 2009 | JVC VDW14DU Single Unit 2x DVD-RW Storage...
No computer will recognize my player any longer and I don't know why. It did for months and now all of a sudden it will not. Please help!!!
• The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive.
• In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive. This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced.
• The difference with media files, specifically music files, is that they demand much more management.
• Downloading services can require special licensing and a limit on the number of playbacks a music file can have.
• The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers.
• For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP.
• Those with Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center.
• We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the power button on your device once it’s connected to the computer until the USB icon disappears.
Jan 08, 2009 | GPX ML648B MP3 Player
Mtp
  • The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive. In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive.
  • This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced. The difference with media files, specifically music files, is that they demand much more management. Downloading services can require special licensing and a limit on the number of playbacks a music file can have. The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers.
  • For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP. Those who have Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center. We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the button on the top of your player marked M
  • -Tha Mp3 Doctor
    Oct 29, 2008 | GPX MW3836 MP3 Player
    Uploading videos and films from my windows media player to my Archos.
    Check if you have windows media player 11 installed. then go to Setting->System->USB Preference and switch between Windows Media Device, PC Hard Drive, and PC Hard Drive (auto ARCLib) modes. Hope this will work. All the best.
    Aug 26, 2008 | Archos 405 Digital Media Player
    Sansa E260 Transfer Music with Yahoo Music Ulimited
    1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
    2. 2 Open up 'My Computer'. You should see it under the list of available drives.
    3. 3 Check its contents first to make sure that you have the right drive.
    4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
    5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
    6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
    Thanks
    Jun 13, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
    Archos 605 copying films from DVD to the player
    If change the setting of the 605 to "hard disk" then a PC sees the 605 as a hard disc when connected using the usb lead. You can then copy and paste files directly to the 605..
    Feb 19, 2008 | Archos 605 WiFi Digital Media Player
    Can't put songs onto the MP3 player
    I ALSO HAVE A ZEN MICRO, I PURCHASED IT FOR USING WITH THE NAPSTER SERVICE NAPSTER TO GO. I TO HAVE THE SAME SORT OF PROBLEM I WAS FULL OF TRACKS AND IT THEN STOPPED RESPONDING SO I DID A RE FORMATT SO ALL THE TRACKS WERE LOST. EVER SINCE THEN WHEN I TRY TO LOAD TRACKS FROM NAPSTER ALL I GET IS A TRANSFER ERROR (I/O ERROR) THESE TRACKS WERE ON IT BEFORE AND IT TAKES FOREVER TO LOAD. I HAVE TRIED CREATIVE BUT THEY WERE CRAP AND THERE EMAIL CUSTOMER SUPPORT IS A JOKE. NAPSTER TRIED TO HELP BUT AFTER 6 40 MIN CALLS STILL NOT WORKING THEY KEEP GOING OVER THE SAME THINGS. I HAVE TRIED WEBSITES LIKE THESE BUT TO NO AVAIL. DO YOU KNOW OF ANYTHING OR HAVE ANY SUGGESTIONS, I AM A COPMPLETE TECHNOPHOBE BUT I WILL HAVE A GO.
    Sep 03, 2006 | Creative Labs Zen Micro MP3 Player
    Computers & Internet Logo
    100 people viewed this question
    Top Memup Computers & Internet Experts
    David Payne
    David Payne
    Are you a Memup Computer and Internet Expert? Answer questions, earn points and help others
