Problem in proxy settings
How to open outgoing tcp connection...... i'm facing errors in sending sms to mobile while connecting from internet........... the details are as follows
Log Out...Could not Connect...
Dear User, If you are behind a firewall or within a company local area network (LAN), you will need to open outgoing TCP connections to Port 51215 on your proxy server.
  • 3 more comments
  • Anonymous Nov 07, 2008
    I Opened a port but it didn't fix my problem.
    i have the same problem
  • Anonymous Nov 14, 2008
  • Anonymous Nov 22, 2008
    same problem while sending a chat message.
  • rizvi07 Dec 17, 2008
    on windows vista
Posted on Nov 24, 2008
    Problem Solver:
  • 7 Answers
What firewall are you using? If it's a built in windows firewall eg in XP, try this link:
http://support.microsoft.com/?id=308127
Posted on Nov 22, 2008
Sir I am unable to set my vodafonelive on my motorola l9 slvr set please give me mannual setting in paticularly thanks kamal
Manual Vodafone Live GPRS Settings
Settings Name: any
Home Page: http://www.hutchworld.co.in
Session Mode: Permanent
Connection Security: off
Data Bearer: GPRS
GPRS Access Point: portalnmms
IP Address: 10.10.1.100 Use proxy? yes
Authentication Type: Normal
Login type: Automatic
User Name: <blank>
Password: <blank>
Activate Vodafone GPRS through SMS If the above settings does not work for you, you can sms to vodafone server to activate vodafone live or vodafone mobile connect.
  1. send ACT VL to 52586 to activate Vodafone live! (MMS & Wap Access),
  2. send CAN VL to 52586 to deactivate Vodafone live!, send ACT VMC199 or ACT VMC499
  3. ACT VMC699 to 56789 to activate Vodafone Mobile Connect (Web Access on phone or Laptop/PC)
Dec 27, 2010 | Motorola Mobility L9 Unlocked GSM Cell...
Unlocked LG Vu won't send or receive picture messages
go to messaging. go to settings. multimedia message. message center. options new.
name= T-Mobile MMS
MMSC url=http://mms.msg.eng.t-mobile.com.mms/wapenc
MMSC proxy=216.115.174.050
MMSC port=8080
Connection mode= TCP without proxy
Network profile= T-Mobile WAP
Autorization=PAP
leave username and password blank.
Apr 23, 2009 | LG Vu CU920 Cellular Phone
Urgent
hi,
As per your description,in your d link firewall outgoing 51215 port is not opened.go to the access-list or security policy or access rule (I am not sure about the name) tab.make a entry like
to:the sms site ip.
service:51215
action:accept.
Regards,
Mani.S
Mar 10, 2009 | D-Link DFL-800 Firewall
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
->OK->Next->Finish
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
->OK.
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy http://www.analogx.com:80/files/proxyi.exe (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - http://gnubox.dnsalias.org/gnubox/ ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Options->Settings->Connection
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
How to open outgoing tcp connection...... i'm facing errors in sending sms to mobile while connecting from internet........... the details are as follows Log Out...Could not Connect... Dear User, If you...
Follow these steps:
Start-> Run-> cmd
In the black box type: ipconfig [enter]
You should see some numbers like this:
192.168.*.* IP
255.255.255.0 Sub
192.168.*.* Gateway
Go to an Internet Browser and plug in your Gateway address like this:
http://192.168.1.1
or
http://192.168.0.1
Now your username and password will be like:
admin:admin
admin:1234
admin: {no password}
{nouser}:admin
{nouser}:1234
You get the drift.
Once you are in you can manipulate the firewall and port forwarding settings...
Nov 12, 2008 | D-Link DFL-800 Firewall
Gprs settings and mms settings airtel prepaid connection
I think you are asking for the phone settings for airtel gprs. Sinceyou haven't mentioned whether you want for airtel live or mobileoffice, i've provided you both.
Airtel live:
Connection Name> Airtel Live
Data bearer>gprs
Access point name>airtelfun.com
User Name/Password>(leave blank)
Authentication>Normal
Homepage>live.airtelworld.com
IP Address>100.1.200.99
Connection Security>Off
Session mode>Permanent
Mobile Office:
Connection Name>Mobile Office
Access Point Name>airtelgprs.com
Homepage>www.google.com
IP Address>0.0.0.0
Manual Airtel Gprs Settings
  1. Homepage - any page you want to set.
  2. User Name - Blank
  3. Password - Blank
  4. Proxy - Enabled/yes.
  5. Proxy and Server Adress - 202.56.231.117
  6. Proxy and Server Port - 8080
  7. Data bearer - GPRS or Packet Data.
  8. Access Point Name - airtelgprs.com
  9. Authentication Type - Normal
  10. Use preferred access point - No
Manual Airtel live settings
  1. Account Name - Airtel_live
  2. Homepage - http://live.airtelworld.com
  3. Username - Blank
  4. Password - Blank
  5. Proxy - Enabled/yes
  6. Proxy and Server Adress - 100.1.200.99
  7. Accespoint Name - airtelfun.com
  8. Proxy and Server Port - 8080
  9. Data bearer - GPRS/ Packet Data
  10. Authentication Type - Normal
Hope it helps.
Nov 03, 2008 | Sony Ericsson w580i Cellular Phone
I have an unlocked lg viewty and i have t-mobile web access but it wont let me in to any websites it keeps saying error
http://tmobileuspublic.wdsglobal.com/phonefirst
Go to that link. Its a configurator that can send the correct settings to the phone. Just select the manufacturer and model and follow the directions. What is the specific error? Just Error? If its something like http $code$ error then thats a network error, not phone.
If that doesnt work try this manual setup:
Setup Access Point:
  • From the Main menu go to Tools > Settings > Connectivity > Network > Access Points
  • Create New or Edit existing
  • Set the Name to T-Zones
  • Set the Access Point Name to wap.voicestream.com
  • Note: If you signed up for Total Internet, use internet2.voicestream.com or possibly internet3.voicestream.com
Setup Profile:
  • From the Main menu go to Browser > Settings > Profiles
  • Set the Profile Name to T-Zones
  • Set the Homepage to http://wap.myvoicestream.com
  • Set Connection Mode to TCP with Proxy
  • Set the IP Address to 216.155.165.050
  • Set the Proxy to 8080
  • Set Access Point to T-Zones
Aug 23, 2008 | LG Cell Phones
Unable to conenct to Mobile Browser
Hi there
You cannot connect to your mobile browser because your GPRS or GSM isn't set up. You must call your service provider's customer care and ask them to send you your GPRS or GSM settings, they will then send you your settings via SMS, save this SMS and then the phone should ask you if you would like to change the current proxy, choose "accept" or "yes".
You cannot view or send images because your MMS isn't set up. You must call your service provider's customer care and ask them to send you your MMS settings, they will then send you your settings via SMS, save this SMS and then the phone should ask you if you would like to change the current proxy, choose "accept" or "yes".
Please remember to rate this solution as FixYa if it helps you.
Kind regards
Dustin Ellse
Jun 30, 2008 | LG Shine KE970 Cellular Phone
LG KU990 mms & browser settings for tmobile
Just got me a LG KU990 recently and I had to program the MMS Settings manually as well. I have T-Mobile. And this worked for me.
STEP 1) Main Menu (4 Dots on main screen) >Settings > Phone Settings > Connectivity > Access Points
T-Mobile should have automatically sent you a free text message that allows you to install/download some settings if not, from Access Points, go to Options > Add New
Then enter the following information:
Connection Title: WAP Settings_OTA
Bearer:GPRS
Authentication:PAP
Username:(LEAVE BLANK)
Password:(LEAVE BLANK)
APN: epc.tmobile.com
Save it.
STEP 2) Go to Messaging > Settings > Multimedia Message >
Multi Msg Centre > Options > Add New
Title:MMS Settings
MMSC URL:http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS Proxy:216.155.165.50:8080
Connection Mode: TCP with Proxy
Access Point: WAP Settings_OT
(from Step 1)
Save it. And it should work. If not, go the the T-Mobile website. Hope it works out.
Feb 15, 2008 | Cell Phones
Computers & Internet Logo
1,215 people viewed this question
David Payne
David Payne
