Question about JVC FS-GD7 Shelf System
Jvc fs-gd7 tray error
Tray will not open
2 Suggested Answers
SOURCE: 'P-ERROR' message on my JVC FS-GD7
Maybe the amplifier IC are damaged and need to be replaced
Posted on Aug 03, 2009
How do I fix a JVC FS-GD7 Tray Errror
Just pull the top cabinet cover off, it is all there.
Dec 08, 2016 | JVC Car Audio & Video
Jvc stereo tray error fs-s77
Model number is not correct. Give the JVC model number
Sep 15, 2013 | JVC AM FM CD DET FACE CAR STEREO
My jvc 5 disc player wont play cd nor dvd.says tray errr. wont open to eject dics or play
It is possible that the loading belt needs to be replaced, or the timing gears are out of sink, either way it must be taken apart to find the problem, sometimes I find the gears ware out causing the unit to lock up. When you hit the eject button do you hear a motor running? that should be the sound of the loading mechanism trying to eject the tray.
Dec 23, 2010 | JVC FS-GD7 Shelf System
(tray err) what does that mean?
The tray that holds the CD disc is malfunctioning.
Dec 05, 2010 | JVC FS-GD7 Shelf System
Aug 03, 2009 | JVC FS-GD7 Shelf System
JVC UX S77 my 5 disc cd says "tray err". It won't open or play.
it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
May 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
It won't play DVD's but will play CD's and VCD's. Was exposed to smoke.
I think that a lens cleaning disk would fix the problem..
Apr 24, 2009 | JVC FS-GD7 Shelf System
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
Tray error
I saw on another JVC systems manual that its an error message that shows when the tray isn't fully open due to an obstruction. If you can locate a manual eject button(usualy you'll need to insert some tip into it) it will help you eject the tray and look for any obstructions, anything looking out of the ordinary there. at least that way you'll be able to take your cds out... You can also try disconnecting the system from all power sources for a few days(including an internal battery), maybe the reset will jog it back to working order. If you're out of warranty and know your way around those things, try taking it apart, cleaning as much as you can, and look for anything out of the ordinary, like broken gears or pins, bent parts, a cog, etc. Good luck
Feb 12, 2006 | JVC FS-S77 System
JVC FS-GD7 Shelf System Logo
42 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
