My sony lcd kdl 32l-5000 tv wont turn on , even the led light is irrespnsive
I tried changing the location of the tv to see if the ac cable was gone but it is not working in either place i checked the back for voltage and its all working but no screen picture or power to the front
  • 8,617 Answers
Have you checked the main fuse on the power supply to see if its blown? Also I would check the tops of all capacitors on the power board to see if the tops of any of them are swelled up on top (indicating a bad cap) If yu need further assistance let me know and I will assist.
Posted on Feb 21, 2012
mistersony
  • 320 Answers
SOURCE: Sony Bravia KDL-40V2500 40" lcd hdtv
I risk getting a bad rating from you, but it sounds as though you have a bad LCD panel. I have seen sections of the panels fair, usually caused by a separation of the ribbons connecting to the panel itself or a bad TCON board (the board that addresses the pixels. It is part of the panel on Sony TV's). Your best bet is to contact Sony customer service at 800-222-SONY to see if they will work out some kind of accommodation on the repair, like possibly covering the parts or splitting the repair costs with you. I hope I have provided you with good information and you do not rate me poorly for your bad news.
Posted on Nov 10, 2008
SOURCE: remote code for Sony KDL-52WL35 LCD TV
need the code for the sony 1080 tv please
Posted on Jul 20, 2009
milkburp
  • 416 Answers
SOURCE: KDL-32ML130 Sony Bravio 32' LCD HDTV motion blur
Logic board? Are you referring to the Main PCB (BU board I think). This issue is caused by the Timing Control board (T-CON). It’s the board directly on the panel that connects by LVDS cable to the Main PCB. Not sure if it’s a part you can purchase separate from the LCD panel, but give it a whirl… you never know. I hope this was of some assistance.
Posted on Mar 25, 2010
  • 4 Answers
SOURCE: KDL-46XBR2 sony broke lcd screen
I had a kdl46xbr2 go out on me repair company said screen went bad and they told me warranty dept would not fix it cause the screen ran 2800. So now im in dis with them for a replacment tv and they wanna give me the xbr9 i want the xbr8. Theres a reason i spent 3500 on the xbr2 the bravia pro engine is in a nother class than the standard bravia.
Posted on May 13, 2010
  • 8909 Answers
SOURCE: Sony KDL-40S4100 Bravia LCD will turn on for like
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Posted on Mar 28, 2011
Sony KDL-52V4100 TV turns on for less than a minute then loses picture, why?
Nice TV ,but, is an LCD . most likely cause may be after long service life the 'Cold Cathode' tubes have begun to grow a carbon track down from the high voltage input . This causes the power supply for that voltage to determine too much load and shuts down . I am surprised you do not see a flashing LED pattern but this does not mean that the condition was communicated to the ECU .
That is a lot of tubes to change at about 40 usd for 10 pieces . It is also a Pain in your seat cushions to disassemble to confirm (ie: delicate connections to undo , mechanical puzzles to solve) I have seen Youtube videos of people converting to LED backlights with very nice results . It is possible but not recommended to change just the bad ones , you will soon have to do the rest anyway .
There may be a shop that does it often and could save $ compared to replacing with LED tv set that size or maybe a shop that converts(not me!)
Luck ... Hugh
Mar 10, 2017 | Sony BRAVIA KDL-52V4100 52" LCD TV
Hey so my sony Bravia LCD 55" TV if blinking a red light 5 times and won't turn on...... any idea what I need to fix and how? Oh model # kdl-55ex640
HI
if your modal no is KDL-55EX640 & red light is blinking 5 times then your led panel is defective so please change your led panel in this case
Apr 09, 2015 | Sony Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Nov 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
Dec 10, 2017 | Sony KDL-32M3000 32 in. LCD Television
I have a sony bravia model # kdl-40s4100 40 in that wont power up what are the problems that could cause this?
If you have the led light on, then you need to replace the mainboard.
If no led light then replace the powerboard.
Jun 06, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
