Question about Samsung CLP 300 Laser Printer
Samsung CLP-310 'dev. home error' - Samsung CLP 300 Laser Printer
namizhka
  • 148 Answers
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Posted on Apr 17, 2009
SOURCE: Brand New printer status led RED, Smart Panel error "dev home"
I have been able to get my printer working by doing the following:
1. install latest drivers, for me this was ver.3.04.80:43
2. unplug usb cable from computer
3. unplug power cable from back of printer
4. open front cover and remove all toner cartridges
5. plug power cable back in and start printer up
6. replace all toner cartridges to their respective places and shut front cover
7. plug usb cable back into computer
after following these steps the error was cleared. yrmv.
please post if this solution works.
Posted on May 07, 2009
jyvibar
  • 148 Answers
SOURCE: samsung clp 310 printer regularly jams
avoid using paper that is below 50 gsm
Posted on Mar 26, 2010
  • 113 Answers
if your printing is halfway to the exit. it is most likely the exit sensor is mulfunction.
get the exit sensor replace.
Posted on May 21, 2010
My error is dev home error
o to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
Dec 10, 2010 | Samsung CLP 300 Laser Printer
Will not print
change cartridge chips or all.
Jun 01, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 'dev. home error'
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Dec 26, 2009 | Samsung CLP 300 Laser Printer
Dev. home error
you have to call the service, this problem couldn't be solved without special equipment and spare parts
Oct 14, 2009 | Samsung CLP 300 Laser Printer
Red status light. Dev. Home Error?
The Transfer Belt has a defect. Perhaps it is disrupted.
Aug 02, 2009 | Samsung CLP 300 Laser Printer
Dev. home error
main drive assy faulty.need replacing.
Jul 10, 2009 | Samsung CLP 300 Laser Printer
I have a clp-350n samsung colour printer. Prints B+W images fine. When a colour image is sent to the printer the printer runs and runs and runs but never prints anything. It's as if the imaging belt can't...
There is an "opto coupler" in the main drive gear unit (right ride of machine) which controls the drive to the toner/dev units. If this (or part of the drive) is faulty it will give this error.
Jun 17, 2009 | Samsung CLP-315W Laser Color Printer
Samsung CLP-315 Dev Home error
It appears that the Dev. Home error is very common for Samsung printers. It obviously has different reasons. In my case I solved it by stabilizing the deviation clutch. It was too unsteady and the dev. sensor recognized a fault.
The dev. clutch is situated under the right cover, which is the power supply side of the printer. To remove this cover you need to firstly remove the top cover, which is held by two screws on the front. Then uncover the right side by unscrewing one screw on the back, near the power supply inlet and unclip a couple clips on the top side of the cover. After removing it you have to find the deviation electrical clutch. Check if it is too unsteady. If it easily moves, you need to somehow stabilize it, in my case by a couple of leather straps under it, so that they press it up and make it steady: 5_19_2012_1_08_58_pm.jpg
After that simply check if you have stabilized it properly. If you have the green light must turn on after switching the device on.
NB! Be extremely careful when power is ON, because there is high voltage running. I'd suggest that you would stabilize the thing with non metallic item to keep safe. Good luck!
Apr 13, 2009 | Samsung CLP 315 Laser Printer
Im getting a DEV. HOME ERROR MESSAGE! PLEASE HELP?
The Image Transfer Belt (ITB) is not correctly installed or defect.
Pull out the Drum Unit (open front door and take out the hole assambly) Than you can look on the ITB, you can pull it out, it's a bit ricky to get it in position again.
Mar 19, 2009 | Samsung CLP 300 Laser Printer
Home dev. error
reinstall the affected dev assy, or try to removed and put back again
Oct 25, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
427 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
