Question about Music
Where I found the schematic ampli bass Peavy combo 210 tx ?
Ampli bass Peavy combo 210 TX ....It has broken down fuse jumps from the bet under high pressure, I search the electronic schema. Thank You
3 Suggested Answers
  • 5603 Answers
SOURCE: Hi, i need full electronic schematic
See if this MIGHT be close...Power amp:
http://elektrotanya.com/gallien-krueger_backline-210_350_sm.pdf/download.html
and preamp
http://elektrotanya.com/gallien_krueger_bl250_210_350_115_600_preamp_206_0181.pdf/download.html
Note this site will only allow two downloads per day without registering...
Scroll down to the link at the pages and click on "Get Manual"
Posted on Apr 12, 2011
  • 5603 Answers
SOURCE: there are some burnt carbon resistors beyond
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
Posted on May 24, 2011
After playing a a few small gigs my husbands Hartke vx3500 bass amp cuts out with the sound BUT the head seems to stay lit up, dont have problems when a low volume but during a gig has randomly cut out for...
It has something loose on the board or where the speaker wires connect. Combo amps are really bad about doing this. The vibrations from the speakers loosen the components on the board.
Sep 03, 2011 | Hartke VX3500 Bass Guitar Combo Amplifier
Brand New Ampeg Ba 600 210. Only Used durin 2 shows. Sound is awesome. Go to use it this weekend and absolutely no sound at all coming through the speakers. Compression, eq and Everything else working when...
Another person posting on here I suggested opening his unit and he had blown speakers. I think these that are DOA after previous use may be blown during the previous shutdown of the amp driving them and those with built in amps are blown when mixer is powered down putting out a large pulse. Hopefull the amp is blown rather than the speakers... cheaper to repair. Open and check for a fuse, but dont' replace it until you find out the cause of it blowing as additional damage can occur.
May 15, 2011 | Ampeg BA600-210 Bass Combo (with )
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
Hi, i need full electronic schematic GallienKrueger MB210 Amp Combo Bass, you have it?
and preamp
Apr 12, 2011 | GallienKrueger MB210 Amp Combo Bass
Older peavy 4 string bass with batteries need wiring shematics
I think posting the wiring schematics is not legal. If it just does not work anymore you could try and look if the battery clip is oxidized and try to clean it.
Feb 27, 2011 | Peavey Millennium Bxp 4String Bass Guitar
Can i fix one ampli marshall mg100 i had used my bass, and now my marshall have a very estrange noise
Well i know ive destroyed a guitar amp with a bass guitar before :-p this is why they make bass amps and guitar amps instead of just amps
Sep 25, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Fender Rumble 100 210 pop noise then hum after strong low e note
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Music Logo
151 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
