SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
SOURCE: Xerox workcentre 24 paper lifter problem 007-293
Go to www.thepartsdrop.com for xerox parts.
SOURCE: Xerox WorkCentre M-24 and Windows Vista Home Prem., 64 bit DRIVER
call 1-740-676-8000 ask for Jordan.
SOURCE: Need to enter service mode on a Xerox 7435
The service tech should do this. The 7435 should be less than 3 months old, and Xerox should fix it. If you bought it from Global, or another company that does not actually employ Xerox technicians, try appealing to them, but I cannot tell you for sure what the outcome will be. Buying from an authorized agency ensures that you can use your "Total Satisfaction Guarantee".
SOURCE: What is the default password for the Xerox
It looks like the username and password are both 'admin', and if that doesn't work it might be '11111'.
I found the manual here, which might help for future problems: http://download.support.xerox.com/pub/docs/WCM24/userdocs/any-os/en/WCM24_Quick_Connect_Guide.pdf
