Question about GE GDS18LBR Bottom Freezer Refrigerator
How to fix the noise problem - GE GDS18LBR Bottom Freezer Refrigerator
How do i fix rear diffrential?
Generally the noise in the differential comes from backlash in the gears. Serious problem. Either rebuild or replace the differential. You could pump the gearbox full of grease to hide the noise and the sell the car.
Feb 20, 2015 | Cars & Trucks
My car is BT50, I have a problem about flywheel, Noise while driving,I haved fixed it for many times from Mazda Service Center but it still the problem, Help me.
You cannot get a noise from from your flywheel in normal driving.If you have had it fixed many times,it was not fixed.
You can have a clutch noise,a gearbox noise,a thrust washer noise,etc. etc.
Go back to Mazda and ask if you can talk to a person that knows what the problem is.Not the idiots they get on the front counter.They only say what the bosses tell them to say.
Hope this helps
Apr 05, 2011 | 2007 Mazda B Series
Horrible noise
do u have fixed properly drum unit do u have tested with the older drum is the same i think you dont have fixed proply thats ywhy u getting noise from gears just try to fix proper thanks
May 12, 2010 | Brother IntelliFAX 4100 Laser Fax
The Fan is rumbling, making noises- can it be
Often simply cleaning them carefully (no water of course) and oiling the motor will fix these noises. Occasionally they are too far gone, but this will fix most of them. Good luck.
Mar 22, 2010 | Broan-NuTone QT100L Fan
Rattling noise between 1000-2000 rev....
Its a dealer fix problem. Its under warranty take it back and tell them to fix it. If they cant hear this noise then ask to have a tech. ride with you and when u hear it point it out to the tech.
Jul 23, 2009 | 2008 Toyota Yaris Sedan
2002 A4 Steering noise
The old saying, " If it ain't broke don't try to fix it!" Just keep an eye on tire wear and strange noises.It should never leave you broke down. Frankster016
Oct 26, 2008 | 2002 Audi A4
Bad Rod?
you can fix it. you shouldn't drive the car anymore to prevent damaging other parts. it sounds like a spun bearing, which is cause when the bearing doesn't recieve enough oil. the bearings are usually in a fixed position with the crankshaft rotating between them. the knocking noise is from the bearing wearing down from lack of oil, and they start rotating with the crank.
it might not be worth fixing because the cost of fixing it may be more than what the car is worth.
Oct 13, 2008 | 1999 Pontiac Grand Am GT
GE GDS18LBR Bottom Freezer Refrigerator Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
