Question about Radio Communications
Hi. This Sansui 40 inch was working fine with an antenna. The Boy hooked up his playstation 3 and now it doesn't get any channels. Checked all the connections, disconnected the PS3, Tried doing th
    Genius:
  • 1,212 Answers
You likely need to add an antenna amplifier. The PS3 should have been hooked up to one of the other source inputs other than the antenna. If it was attached via the antenna, a solder connection may have come loose or the coax got kinked.
Posted on Feb 25, 2012
How do i hook up a 32 inch Sansui TV to an antenna
After you connect the antenna cable to the TV go into the setup mode and on the tuner line change it from cable to air. Then do an automatic channel search and you're done.
Oct 22, 2015 | Sansui Televison & Video
How to adjust the antennae to get signal uniden 538w
doesn't matter what kind of radio the procedure is the same.First you need an SWR meter.now hook it up properly and take a reading on channel 40 ,write it down then channel 1 , write it down.now channel 19 and write it down . If the number on 40 is higher than on 1 your antenna is long and it has to be adjusted take the allen wrench provided with the antenna and loosen the tip.Bring the tip down about 1/4 inch at a time checking both channel 40 and 1 as you do this . onnce you get a good match then you are ready to go.
Aug 29, 2014 | Uniden Radio Communications
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
A k 40 magnetic antenna has high swr and wire and everything looks fine
The K40 is known to fail after that many years in service when moisture gets into the coil it causes it to change it resonance freq. and hence the higher SWR. Buy and new antenna and enjoy 10 years is way to long for an antenna to last.
Apr 05, 2014 | K40 CB Antenna K-30
LG37LG5020
hi. that:s be reset factory could do. if no you need a technician . good luck!
Sep 07, 2012 | LG 32LG30 32 in. LCD HDTV
Swr to hi and can t get it down
I hope this will help you on setting your swr put the radio on channel 1 check your swr.
now go to channel 40 check the swr. If the swr is lower on 1 than it is on 40 the antenna must be shortened buy 1/4 inch.until you reach your desired swr.if the swr is lower on 40 than it is on 1 the antenna must be lenthened by 1/4 inch until desired swr.
Mar 28, 2009 | Cobra 29 LTD CB Radio
Sansui HDLCD1908 not recieveing Digital channels
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Jan 06, 2009 | Sansui 19 in. LCD TV
Sansui 27 inch # DTV2798
Yes. It takes a while to scan for all the channels.
Jul 09, 2008 | Sansui Televison & Video
Radio Communications Logo
42 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
