My car is burning alot of gas why is that
SOURCE: Where is the Fuel Gas
The fuel filter is located WITH the fuel pump it is called a fuel module, it is what Mitsubishi calls this bundle, to access remove rear seat cushion under it you will find the a sheet metal access cover, under that cover is the module assy. This will be a new fuel pump and filter you are replacing, so make sure you are doing a repair you need first.
SOURCE: Paint code for red 2001 mitsubishi lancer paint sk
try looking at the vin plate inside the engine compartment. it should be the first set of three alphanumeric characters. the plate is exactly in the center right near the windshield.
SOURCE: fuel pump in a mitsubishi lancer 91.
The fuel pump is located in the fuel tank and you can reach it by removing the back seat.
Rate this fixya!
SOURCE: I hae a 2002 mitsubishi lancer I need wiring radio
i dont have a pic but it goes like this..
(color1/color2 usually means the wire has a stripe or dots on it)
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
SOURCE: 2002 Mitsubishi Lancer won't run. No spark out of
YOUR CAR ONLY HAS COIL PACKS. CHECK VOLTAGE AT HARNNESS, IF OK REMOVE COIL PACK FROM SPARK PLUG REMOVE BOOT CHECK FOR VOLTAGE THERE, IF NONE POSS. COIL PACK.
my car mitsubishi lancer 2002 is burning alot gas what causeing that to happen
