Question about Sony DAV-DZ100 System
Calibration mic problems
Just brought the Sony DAV-DZ111. I have been trying the auto calibration but when i connect the calibration mic it keeps say the measurement has failed and i need to check the connection. This is the second machine I have had both with this problem. What am i doing wrong? Thanks
  • oiac93
    oiac93 Apr 07, 2013
    Hey, i have the same problem. you solved the problem?
Seems like sony gave out cheap mics....When in doubt grab the mic off your computer( most people have one) plug it in just to see if it works, mine did!
Posted on Jan 22, 2010
I had the same symptom on a SONY DAV-DX375. The problem was I didn't have the mic plugged in far enough. The receptacle is very tight even though it is very tiny. Make sure to push plug in until the plastic part is against the front panel. It sounds obvious, but I was surprised how much force it took to seat the plug.
Posted on Jun 24, 2008
I have a Sony HF_ST-1000 cinema system and missing the calibration mic. Can I use a normal dynamic mic?
Posted on Mar 09, 2010
Ive just bought a second hand DAV-DZ111 And when connecting the calibration mic the system tells you to unplug headphones? which i do not have connected can you help
i'm sorry.have you plug in the mic into mic in?
have you test the mic yet?
is there sound?
you can test mic with another audio system.or try another mic into.
Mar 09, 2010 | Sony DAV-DZ100 System
Auto rotate not working. g sensor calibration not
I have the similar problem on my touch HD. its vertical calibration bubble is not in the middle and pressing calibration is not fixing the problem. Auto rotate is also not working! Any one knows the solution??
Oct 25, 2009 | HTC Touch HD Smartphone
Disc tray keeps opening/closing on DVD recorder
my dvd player sony cinema entertainment system dav-dz111 the tray is opening again after closing
Sep 22, 2009 | Televison & Video
I need help with my surround sound!!
The calibration mic thing is to balance the sound evenly on surround sound systems, it replacles the older systems "TEST TONE" speaker setup, in other words it will balance each speaker say in a 5.1 setup to adjust the level output so the listening position is not overwhemled by say the rear surround speaker overriding the front left & right speaker or the most critical the center speaker. The calibration mic uses computer tech to make it easier for the user, no sound pressure calibration is needed as with the test tone setup mentioned earlier. The wireless speaker situation could be possibly waiting for the calibration confirmation, Read any user manual information if available.
Jan 25, 2009 | Sony DAV-DZ100 System
C13:00 error
C13: ERROR MEANS THE DVD DO IS NOT COMPATIBLE THE THE PLAYER, TRY IT WITH OTHER DVD PLAYER IF YOU HAVE ANY, I DO HAVE ONE AND MINE PLAYS ONLY ORIGINAL COPIES AND HAS TO BE THE UNIQUE HOOKE ON THE TV, NOT OTHER DVD. NO COPIES FOR THIS PLAYER
Aug 26, 2008 | Sony DAV-S300 System
Cannot get "Test Mode Menu" with remote
Press and hold mute and return on the player and turn the volume control clockwise, the setup menu will appear after a few seconds.Go thru the menu and do the required disc calibration.Do not mess with settings you don't understand, else you'll create more problems than you solve.Have some good single,double layer DVD ,SVCD and CD for the calibration.
Cheers,
Patrick.
Dec 21, 2007 | Sony DAV-S300 System
"No Disc"
Here are a couple solutions:
How To Recalibrate DVD Player
Summary:
For those that are having the skiping up and unreadable disk problems try the following calabration. I did it last night and now my DVD's are much clearer and I'm hoping the skiping problem is gone.
For those that have the lip sync problem Sony should cover this for no charge, you just need to push them a little. This is a firmware update, have a look at the other posts at this web site to find the firmware revision that you need.
HOW TO PERFORM THE CALIBRATION
Make sure that the DVD player is turned OFF and in the stand-by mode with the little red LED glowing above the on/off button.
To enter the service mode/test mode, press Title, Clear, and Power on the remote.
This will produce the following menu:
Test Mode Menu
0. Syscon Diagnosis
1. Drive Auto Adjustment
2. Drive Manual Operation
3. Mecha Aging
4. Emergency History
5. Version Information
6. Video Level Adjustment
Exit: POWER Key
What each item does;
Syscon Diagnosis = Leave this for service technicians.
Drive Auto Adjustment = Automatically calibrates DVDs and CDs.
Drive Manual Operation = Manually calibrates DVDs and CDs with prompts for permission to skip, execute and/or proceed after each adjustment is made or skipped. Offers a fascinating look at all of the many adjustments made, but this method is time consuming.
Mecha Aging = Allows auto repeat mode for testing purposes.
Emergency History = Shows the number of hours on your machine.
Version Information = Shows firmware version.
Video Level Adjustment = Test pattern.
Press #1 (Drive Auto Adjustment) on the remote and the following menu will appear:
0. All
1. DVD-SL
2. CD
3. DVD-DL
4. SACD
Exit: RETURN
Press #1 (DVD-SL) on the remote and insert a Single Layer DVD when the drawer opens.
Even though you may be interested in calibrating only a dual-layer DVD, do not skip the single-layer calibration procedure. For some reason, the player prefers to first calibrate a single-layer DVD before proceeding to a dual-layer disc. Error messages may result if the single-layer calibration procedure is not performed first.
Press the enter key and the machine will begin to calibrate all of the playback features. When calibration is completed, follow the onscreen instructions to return to the above menu.
When the Drive Auto Adjustment menu returns, press #3 (DVD-DL) on the remote and insert a Dual Layer DVD when the drawer opens. Follow the instructions as noted above.
When calibration is completed, follow the onscreen instructions to exit from the Test Mode Menu. Now you can turn the player back on and try your dual layer discs to see if the layer change has improved.
If you have any concerns about trying this service mode calibration, leave it for an authorized service facility
Other solutions:
1. To reach this test menu on a DAV-S300, press and hold the "STOP" and "Muting" button on your DVD Player (not remote) and turn the volume nob clockwise about 180 degrees. You will see a flicker. A blue test screen will appear, allowing you to calibrate your DVD. Please note that if you have no technical experience, messing around in this menu can cause serious damage to your DVD. The calibration option will be under: option 1, Disc Drive Auto Adjustment (or words to that effect). Be sure to calibrate a single-layer disc first, then dual layer -- you need to calibrate both types. Good luck.
In order for the STOP + MUTE + VOLUME sequence to work, your player must be ON, but have no disc present. You need to empty the tray, power off the S300 and power it back on. Wait until the INSERT DISC/NO DISC prompt appears. Then try the SMV sequence. And you must use the buttons on the unit, NOT on the remote, to enter the service menu. Once in the menu, use your remote to select the auto calibration menu and go from there.
2. This will fix the C 13:00 problem on any Sony DVD player.
With the machine turned off on standby, press the following 3 buttons
on the handset, in order: TITLE CLEAR POWER. The Diagnostic Start menu will come up on the TV. Select the appropriate button number for "auto adjust". The
machine basically does it all. It asks you to select either a single
layer or double layer disc (whatever your offending disc is.) Ejects
the tray, asks you to put your disc in and then calibrates it. (It's
over in about half a second... painless) Just follow the prompts on the screen
Aug 17, 2007 | Sony DAV-S300 System
Sony DAV-DZ100 System Logo
1,039 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
