Why does my hotpoint wt640 keep flashing H20 and F - 05
Why does my washing machine keep flashing h20 and f-05 i tried toi take out the pump in the bottom and when i unscrewed it it started leaking out smelly water lots of water so i just did it back up what do i do please help
SOURCE: HOTPOINT
either a blocked filter or tap not turned on
Posted on May 02, 2008
SOURCE: hotpoint washing machine aquarius super silent wf620
Dear stacey
Had a similar error message
turned out I hadnt turned the water taps on
check this and if not the problem could be the water sensor in the drum
G
Posted on Jun 27, 2009
SOURCE: h20 error
Hello
I used to get this when i lived with my mum & dad and i can honestly say that it was the water pressure with this machine only a small drop in pressure makes the H20 error code appear you can always add additional water when it comes on so that the cycle can continue. You could find out from your water board if the drop in pressure is a leak in your area?
I hope this helps i had to persist with this problem for 18 months untill a leak around the corner was eventually found and fixed.
Regards
Wendy
Posted on Sep 28, 2009
  • 193 Answers
SOURCE: h20 error on hotpoint
Lift the lid and check that clear hose is connected to the pressure switch.
Posted on Nov 02, 2009
  • 3230 Answers
SOURCE: Error code H20...My washing machine, a hotpoint
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Posted on Mar 02, 2010
Model number wt640 is flashing f-02
This is a overheated pump replace pump or clear blockage to let pump run faster as slow pump can give a f-02 fault
May 12, 2014 | Hotpoint Ultima WF865 Front Load Washer
My washing machine flashes H20
Try to put some hot water and drain it(not too hot)
Apr 08, 2014 | Hotpoint Ultima WF860 Front Load Washer
WT640 Not completing spin cycle.
thats a front loader
the user manual might have the error codes listed
think its a direct drive model
only part of that description suggests its the printed circuit board
are you using a surge protector at the wall power point
Hotpoint WT640 Instructions For Installation And Use Manual
Apr 01, 2017 | Washing Machines
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
My Hotpoint wt640 has an error code F-05, what does this mea and what should i do??
My Hotpoint wt640 has an error code F-05, what does this mean and what should i do??
Feb 21, 2011 | Hotpoint Washing Machines
H20 keeps flashing
  • H20 - Not fillings. Check tap, hose and inlet valves
  • If you have proper water pressure the your water inlet valve on the machine is bad and needs replacing.
Dec 21, 2010 | Hotpoint Washing Machines
My wt640 hotpoint washing machine wont spin and says f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also check the drain pipe 2 so that it can drain out. if you have checked for blockages and can not find any reset machine by switching off at plug for 5 mins then back on and try again hope this helps.
Sep 28, 2010 | Hotpoint WF645 Front Load Washer
Hotpoint WT640 - it's flashing f-05. I emptied the machine and put on another wash and it says the same thing halfway through the cycle?
F-05 normally relates to the pressure switch,which normally points to a blockage.Does the machine empty slowly if so I would check the drain pipe first and if that is ok then you need to look down at the drain pump which may have a blockage in the filter which is inside the sump pipe,this is the main hose from the base of the drum and goes to the pump.
Hope this helps.
Aug 09, 2010 | Hotpoint Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
