Question about Amana Washing Machines
Amana front load washer f20 code - Amana Washing Machines
SOURCE: 2006 kenmore smartwash quietpak4 he3t F20 code washer
Turn on the water.
Posted on Nov 24, 2007
SOURCE: Fault code F20 on kenmore he2t clothes washer
I had the F-28 code error on my 1-1/2 year old Kenmore HE2t. The door wouldn't unlock and I couldn't get the clothes out of it.
The repair tech, after calling other repair techs, decided it was the central electrical unit, page #8540540 (Whirlpool) -- now Part No. W10163007. I ordered it online for about $250 cheaper than the tech was going to charge (not including the additional labor charges).
Posted on Jun 23, 2008
SOURCE: Amana front load washer error code 5d
5d means you're using too much detergent.
Posted on Jul 22, 2008
SOURCE: f20 error code???
Ok, I found 2 solutions for this problem, I tried the first one, and it really seemed to work, but I think I will do the second one too.  First, if you have metal flood safe hoses, you need to look for debris blocking the filter at both ends.  I kept checking the screens at the washer end and not seeing anything, but there was debris located at the water supply end, stuck in the flood safe device that is in the metal hose.  Also, Flood safe hoses say to turn the water on to full pressure, but sometimes that can activate the flood safe device, so only turn your water supply on half way.  Make sure that the hoses are on right as well, the flood safe device needs to be at the end with the water supply, not the washer end.  You will be able to see the device (it looks like a little sieve) inside the hose.
Another cause of this problem can be the filter IN your washer, it is located in the front just under the front bottom removable panel.  If you have a pet in the house, definitely check this out, a lot of hair gets stuck in that.  Just unscrew the front bottom panel, and then it is right in the middle at the bottom, a cone shaped filter.  Get a towel, because there will be water in there, too. Check out this link with pictures: http://enginerdandwife.com/2007/03/kenmore-elite-h3-washer-error-code-hf.html
Posted on Aug 18, 2008
kvhappliance
  • 218 Answers
SOURCE: F20 ERROR ON MAYTAG FRONT LOAD WASHER
Is it filling with water?
Posted on Mar 20, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Code problem on the machine is F20
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
also, those flood prevention hoses they sell you don't work well with front load washers
Jul 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a error code washer mayta f20
"F20" indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Jul 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
When the washer is washing a code F20 will flash
take the top of the washer off there is a book in there that will tell you what f-20 is
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
