Question about Linksys Wireless-G WRT54G Router
How do I reset the router?
I forgot how to properly reset the router
    Genius:
  • 1,269 Answers
There's a reset button at the back of the router. Just press and hold it down for 20 seconds then after that, unplug the power for another 30 seconds then plug it back in. That should reset the router back to factory default.
-Regards
Posted on Oct 27, 2008
Forgot pass word
Press the little recessed Reset button in the rear. You press it with the tip of a pen. Have you checked for a label under the unit?
Once resetting, you will have to set it up again.
Dec 16, 2015 | Belkin Computers & Internet
Orange web signal
Check LAN cable between the router and internet modem. If OK reboot both devices. Connect directly to your internet modem make certain it is connected to the internet properly.
When all else fails, The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Nov 27, 2013 | D-Link D Link Dir 601 Wireless N Home...
Forgot pasword
if you forgot the password you can reset the router back to default settings.
hold the reset button in with a paper clip for 30 seconds powered on.
then try and login using a browser to 192.168.2.1 the default password is blank.
reconfigure the router to your settings.
Feb 20, 2012 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have TP LINK WAIRLESS ROUTER TL-WR642G. I have connected properly, last time i could log in and configure. But now i forgot last password, reset properly the router but cant login by default username and...
You'll need to reset your router if you can't remember the password to get into the settings. There should be a tiny button on the back that you can press with a pen or pencil.
Once it's reset, get on a computer that's connected to the router and type this address into the URL field:
192.168.1.1
This should get you to the settings. If it prompts for a password, try "admin" and leave the field blank.
Feb 28, 2011 | Computers & Internet
Forgot my password to allow other devices to access my network.
Just reset your router and use (admin) for user name and password. To reset your router you can see a small hole in your router which is labeled reset. Use a pin and insert it to the hole and push.
May 31, 2010 | NetGear RangeMax WPN824 Wireless Router...
Had to reset forgot password
If you want to reset the router since you forgot the password for it, the only way you can do that is by pressing the reset button on the router for 10 seconds while power is ON then after that router will be back to its default settings.
Apr 28, 2010 | Belkin F5D8236-4 Router
Forgot my password
If you forgot your wireless password you can log into the web interface and click wireless, then wireless security. If you forgot the router password, the best solution, and this goes for all routers is to locate the reset button (usually a small pin hole on the back of the router). Unplug the router from the power supply and press and hold in the reset button with a paperclip or pen tip. While holding the reset button, plug the power back into the rear of the router and continue holding for 10-15 seconds then release. This ensures that the router is reset to factory defaults and then you can login with default username and password. Hint: usually admin is the username and the password is left blank.
Mar 14, 2010 | Belkin (F5D7230-4) Router (587009)
Forgot router password
The only way is to set it again by resetting the router. With a paper clip, click the reset button on the back of the router and it will make the router configurable again.
Good luck
Jun 07, 2009 | Netopia 2247NWG-VGx Wireless Router...
Forgot password to the router and I just bought a laptop and can not setup the wireless with out the password.
Look in the manual for the proper procedure to reset the password. Normally, there is a "reset" button on the back of the unit that you must press and hold for a set amount of time, perhaps 30 seconds. After the router is reset, the password will be the generic one supplied with it. If you do not know what the generic password is, you can go to google and search for "router passwords," then find your router in the list.
Mar 10, 2008 | Computers & Internet
Wireless router installation
You will need to push in the reset button with a paper clip. The reset button is on the back of the router near one of the antenna.
here are the proper instructions:
http://www.tech-faq.com/forgot-linksys-router-password.shtml
Feb 20, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
