Question about LG 42LB5D 42 in. LCD Television
What is the password for service menu on lg 42lb5d?
3 Suggested Answers
  • 298 Answers
SOURCE: lg 42lb5d base stand
Here's a link to order the original LG base stand assembly for this model (42LB5D) from a major parts distributor. Please note, you would have to verify the complete model number of the unit as their are 2 versions availible (there should be either a C or F at the end of the model #):
LG 42LB5DC Replacement Part Base Stand Assmebly
LG 42LB5DF Replacement Part Base Stand Assmebly
Posted on Mar 31, 2009
  • 110 Answers
SOURCE: I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Posted on Feb 02, 2011
    What are the vesa wall mount specs for the lg 42lb5d?
    If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
    Jan 14, 2015 | LG 42LB5D 42 in. LCD Television
    Menu codes
    LG-42LB5D-UC Service Manual and Repair Guide
    LG 42LB5D UC Service Manual and Repair Guide Download Manuals Technical
    Official factory service, repair and workshop manual. This service and repair manual is used by the Certified LG Technicians. It will help you to troubleshoot and repair your television!
    Please note this is the OFFICIAL service manual in PDF format, no scanned in or bootlegged copy. This manual is made in the highest resolution, so when you print the pages you need it is all in great quality.
    Apr 14, 2014 | LG 42LB5D 42 in. LCD Television
    LG Model 42LB5D T-Con Board Fasilure
    It will be best to use a new genuine T'Con board, rather than a used or repaired one. Contact the authorized service center for LG, to buy it genuine T'Con board. Usually, there is no other adjustments should be done when replacing the T'Con board, provided, with its genuine T'Con. The comes to it price. T'Con board will cost according to brand to brand. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
    Dec 15, 2013 | LG Televison & Video
    Hi, Do anyone can tell me where i buy a LCD scree replacement for my LG 42LB5D???
    it is a better way if you avail the service from the "LG's Authorised Centre".
    Best of Luck !
    Pawan Verma.
    Nov 10, 2011 | LG 42LB5D 42 in. LCD Television
    LG 42lb5d has audio but no picture, but this only happens sometimes when I turn it on. Sometimes it is fine. When it does happen i just turn tv off then on again until it fixes it. I had this tv serviced...
    They may have missed out the power supply circuit. There may be loose solders or bad parts. You may have eliminated other parts which may have caused the problem when the service center replaced the parts. Inspect those that you still have remaining for leaking capacitors, loose parts or loose solders.
    Oct 27, 2009 | LG 42LB5D 42 in. LCD Television
    Lg 42lb5d base stand
    Mar 23, 2009 | LG 42LB5D 42 in. LCD Television
    Remote control of LG 42LB5D
    Here's a link to order the original LG remote control for this model (42LB5D) from a major parts distributor. Please note, you would have to verify the complete model number of the unit as their are 2 versions available (there should be either a C or F at the end of the model #):
    LG 42LB5DC Replacement Part Remote Control
    LG 42LB5DF Replacement Part Remote Control
    Oct 30, 2008 | LG 42LB5D 42 in. LCD Television
    42lb5d settings
    MENU .. KEEP MOVING TO RIGHT >
    Nov 06, 2007 | LG 42LB5D 42 in. LCD Television
    LG 42LB5D 42 in. LCD Television Logo
    59 people viewed this question
