Question about HP DeskJet 920c InkJet Printer
Printer is jammed
Paper went in crooked, therefore it jammed. Tried to get it and and thought I had succeeded, but it would appear a small piece of paper remains. I cant see it but all sorts of weird noises are coming out from somewhere inside! How do I get it out? If I have to remove the printer from the electricity in order to get at the inners(it is on a narrow shelf) will I have to re-program it when I plug it back in? Reason I ask is that I dont know how!
Pull out paper or contact adult.
Posted on Jul 02, 2008
I don't have a solution, I need on. Paper jam and cannot get it out.
Posted on Nov 14, 2007
A warning sign has appeared on the printer, which says: 'Paper is jammed in the printer. Turn off the printer, open the scanner unit, and remove the paper. See your documention'. But There is no paper...
either a sensor broke
or
a small tiny piece of paper is stuck
after removing a jam if the paper tears a small piece of paper can cause the jam error message
Jan 19, 2011 | Office Equipment & Supplies
Paper jams
Please check the following steps:
1.Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Turn off the printer. Remove any paper trays. Look for damaged paper.
3. If necessary, remove the toner or ink cartridge.
4. If you find a piece of jammed paper, remove it.
7. If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8. Replace the toner or ink cartridge and paper trays.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Paper jam, but no jam + paper feed problem
check to make sure there aren't little pieces of paper jammed at the ends of the roller. if you can pop out the roller easily you may find tiny pieces of paper still lodged in there
Dec 29, 2009 | Office Equipment & Supplies
Feed paper is pulled into the right side of printer (facing Printer) and jams. Cleaning no help.Canon Pixma MP600.
I had the same problem,tried and failed with all maintenance tasks including cleaning all rubber rollers and belts,manually turning the rollers and belt,only succeeded in forcing out some small paper debris,but still jamming.Googled for answers,even looking at a technician service manual post by Baido.com,none have provide a tried and succeeded answer,even the paid answers by experts were suggesting the rollers needed to be replaced due to wear and tear,but we are only light duty user,it is unlikely.Next thing you know $3 a question,20 questions later,you are out $60 and still end up with a broken printer . I finally used thick heavy photo papers to test print as they are unlikely to rip and tear when jammed,the first time it made a very loud and very loud grinding noise,I cancelled the printing immediately and slowly and firmly pulled the photo paper out from the front ejecting compartment,a small piece of what looked like a spiral bounded calender type paper came out with the pulling.Tried again with photo paper for printing,this time it made the same loud noise again,stopped print immediately,thought I f-cked up,while carefully and firmly pulling the photo paper ,a small piece of Styrofoam came out.After that every printing test for front paper loader and the front bottom cassette loader work flawlessly with plain paper.I realized that the front loading feeder tray iwas the entrance culprit of these small shits that got inside without any body's knowing.Taped the front feeder tray close,use only the bottom cassette feeder as it is completely enclosed,nothing will get in there.Because a lot of people put things on top of the printer cover when not in use,**** got in there accidentally and stupidly.Hope this will help, saved myself a lot of money and time in setting up new printer to the local and wireless network,I am not a techno guy.Try at your own risk,I had nothing to lose,thought I had to buy a new printer,now the printer is working like new,smooth,quite and fast.
Dec 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MY HP Officejet Pro L7780 prints crooked and jams
Make sure the paper guides are tight against the paper. You can also try cleaning the feed rollers with water and dish liquid on a cloth. Check for any paper that is stuck inside. Remove any rear panels that give a straight-through path and check in there. The smallest piece of torn paper will cause this.
If all fails, buy a Canon MP series ;>)
Feb 15, 2018 | HP Officejet Pro L7780 All-In-One InkJet...
Pixma mp480 jams paper!!! It occurs on the left side Ive tried different paper and it continues to do the same thing I really disappointing because I just bought 4 months ago and I thought canon was a good...
Please try this and also try cleaning the printer and the paper rollers that it has.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
Jamming problem
try this
alternative :
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
HP DeskJet 920c InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
