Question about Invacare Pronto M51 Power Wheelchair
Invacare pronto m51 joystick trouble
dromtonpa
  • 40 Answers
SOURCE: oil / gel leak
If it is coming from your motors, it could be very bad. i.e. motor replacement. Sometimes on the side of those motors there is a black plastic cap about the size of a quarter or half dollar, those fall out sometimes and allow gearbox grease to come out. This should`nt be confused with your motor brush caps which are about the size of a pea and have a small **** in them for a screwdriver.DO NOT TAKE THESE OUT.  If the large cap has come out just stick it back in. If you can`t find it you`ll ned to call a dealer to get the part replaced.    If you can still find no prob,your probably going to have to go to a dealer.
Posted on Mar 26, 2009
dromtonpa
  • 40 Answers
SOURCE: My wheelchair Pronto M51 dose not move, the
Are the motors engaged? It sounds like it is in free-wheel
Posted on Apr 16, 2009
  • 175 Answers
SOURCE: won't move pronto m51
Three lights flashing on your chair indicate a left motor fault. Make sure that all of the connections inside the shroud are tight by physically testing them. If all of the connections are good, and the fuses are good, then it's time for a trip to an authorized repair facility. Here is a link to the M51 owners manual if you haven't one. Page 24 has the fault code guide.
http://www.invacare.com/doc_files/1125085.pdf
The controller monitors all of the functions on the chair, brakes, motors, joystick, charger etc. The three flash fault indicates an "open" circuit. Open, like a switch or blown fuse is open, or a wire is cut or burned in half, or a connector is unconnected, or partially connected. The latter is what you are hoping for. Wires burned in half is the usual cause for a motor fault, and with powerchairs, is usually the result of the chair getting stuck in or against something it can't get out of and the operator over-amping the motors. Motors do, just go bad sometimes, for no reason. Very rarerly, however.
You can also check the brushes on the motor too. There's two quarter-sized black plastic screw-plugs on the ends of the motor opposite each other. Unscrew them and examine the brushes. The springy coils should be springy. Overheating can cause them to be brittle, or even burned in two. Check the lench of the brush, the dark rectangular cube at the end of the springs. It should be curved and polished at the end, and a little over a half-inch long. If it is near a 1/4 inch, it needs replaced, or if there is any evidence of overheating, replace. Good luck.
Posted on Jul 09, 2009
  • 175 Answers
SOURCE: My wheelchair dose not move
The chair has two levers, one for each motor, that disengage it for freewheeling, or pushing the chair without power. These take it out of gear. Place the levers in the locked, gear-engaged position and it should go for you. Here's a link for the manual for your chair, and it will show you where the location is to place it in gear.http://www.invacare.com/doc_files/1125085J.pdf
Posted on Jul 12, 2009
  • 17 Answers
SOURCE: speed control knob has come off
you need Invacare part # 1040225, cost about $6.00. Call these people 866-722-4581
Posted on Sep 22, 2009
Testimonial: "I looked on the internet for this part for HOURS without success. The "FixYa" expert found the model number needed and the phone # to order. Thanks!! "
How do I troubleshoot m51 pronto scooter. When I plug it in there is no lite and of course it does not run
  1. Pronto M51 Troubleshooting‎
    Adfixya.com/Pronto+M51+Troubleshooting‎1000's Solutions
  2. Troubleshooting Tips
  3. Free Diagrams
  4. Free User Guides
Service Indicator Light Diagnostics - Invacare Pronto M51 ...
www.manualslib.com > ... > Pronto M51 > Maintenance manual
Invacare Pronto M51 Base Manual Online: Service Indicator Light Diagnostics. ... Invacare power wheelchair owner's operator and maintenance manual.
Dec 25, 2015 | Health & Beauty
How do I adjust the seat height on a Pronto M51 with SPJ+ Joystick
The seat height can be adjusted by removing the seat and raising up the 4 seat pillars on the bottom frame. With the pivot seat model you can raise the center post seat pillar.
Feb 12, 2014 | Invacare Pronto M51 Power Wheelchair
Pronto M51 feels forced when driving it.
The squealing noise is probably a bearing either in one of the four smaller tires called casters. The problem will not likely cause a break down right away but should be checked by someone mechanically inclined or trained in power wheelchairs. I don't know what you mean by the chair being "forced". Need more info.
May have something to do with batteries.
If the chair is driving slower and batteries are new their is a recall for that joystick from Invacare. Invacare is replacing joysticks for free.
Dec 15, 2013 | Invacare Pronto M51 Power Wheelchair
Invacare pronto m51 moving very slow. moves free and easy when in neutral
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Aug 11, 2010 | Invacare Supply Group Invacare Pronto M51...
How do i know when my invacare pronto m5 is fully charged?
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Jul 11, 2010 | Invacare Pronto M51 Power Wheelchair
Stability locking kit
The M51 does not have a stability locking kit. The Invacare TDX SP has a gas strut stability locking kit that just had an extensive recall campaign associated with it. Please describe your issue in greater detail.
Jul 16, 2010 | Invacare Pronto M51 Power Wheelchair
Circuit Breaker on Pronto m51
Here's the manual. Locate battery cables follow them to the motor and Joystick. you'll see the reset button
Aug 08, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
67 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
