Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony Trinitron KV-21LT1E No longer turns on. Red light comes on
My girlfriend and I were watching her TV one night and we turned it off, then 20 mins later decided to watch some more but the TV would no longer turn on. When we push the power button on the TV, a red light comes on and stays on but, nothing else happens. Would really appreciate some help with this one!
Cheers,
Ian
  • Anonymous Nov 27, 2008
    No longer turns on
techman
  • 3130 Answers
SOURCE: Sony Trinitron KV-27S46
There is a problem in the sweep section of the set. The Horizontal sweep power supply most likly. there is nothing a layman can do as it will involve troubleshooting the solid state circuit. please find a trainded tech to assist you in this repair.
Posted on Sep 22, 2006
IrishDruid
  • 2712 Answers
SOURCE: sony trinitron kv-36fs76u
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other).
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
Posted on Apr 26, 2008
  • 306 Answers
SOURCE: About Sony Trinitron KV-28LS36B
there are two possible defects in your circuit.
However, if the led blinks for about 10 times your tuner is defective 90%.
You will need a scope to check or you will need to take it in for service.
Posted on Oct 15, 2008
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
guitarsam515
  • 15 Answers
SOURCE: Sony FD Trinitron WEGA KV-36FS120 36" TV Problem
The horizontal or vertical output transistors could be suspect in this case.
Posted on Oct 17, 2008
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FX68U problem, blinking power light
Please update this with the count of hte blinks. This is a diagnostic code that will indicate the problem circuit. From that we can tell you probable solutions and their costs.
Thanks,
Dan
Sep 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV 27
Please count the blinks and post that number. That is an internal diagnostic code that will indicate the problem circuit. From that I can give you probable repair parts and costs.
Thanks,
Dan
Dec 24, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron KV-28WS3U Dies
B+ over current protection (OCP), unit goes to the standby mode. Could be a short in the power supply of any of the circuits.
Nov 05, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sep 22, 2006 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
114 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
