Question about Adobe Acrobat 7.0 for PC
Adobe Acrobat 7.1
Hello!  The adobe software comes up with this message every time i make a PDF file from Word (Office 2000). "Adobe PDF printer failed to create PDF file" This problem started recently. Before that i have not had eny problem. Adobe Acrobat is part of CS2. I called support but they only supported the two lates versions, 8 and 9. Can anybody giv eme some tips?
Harald
    Problem Solver:
  • 4 Answers
Usually if this message appears that means you have a problem with the link from adobe to word, because the virtual printer installed by adobe has to work in order for you to save the documents you edit.Some of these messages don't have a real meaning and they are just a message bug, but if you can't save the documents you edit then you need to reinstall the adobe acrobat.
Posted on Dec 09, 2008
I keep getting an error message when I try to save a file as a PDF. It tells me it is unable to initialize the PDF Printer driver.
Try starting adobe acrobat before trying to print/save. If screens come up wanting you to agree to a license agreement, you need to do so. A lot of times, this software gets installed, but never gets started, and therefore never gets the license agreed to! Once this is done, and acrobat is working properly, try to print/save.
If it does not work...
You might try to re-install adobe acrobat.
This can be done by going to control panel and then to add remove programs..
Select adobe acrobat and click remove.
After that, you can re-install using your acrobat disc. If you do not have an acrobat disc, you may find the software up at Adobe's website:
Adobe.com/acrobat
or
Adobe.com/acrobatreader
Once this is re-installed, you should be able to launch the print to file!
Feb 23, 2011 | Broderbund PrintMaster Platinum 16
I have downloaded Adobe Acrobat reader 9, I have made adobe acrobat reader the associated default programme for pdf files and still I am unable to print a pdf file from the internet or e-mail without...
when you send a job to your printer from the internet it is basically the same as downloading the program first before it can be spooled. this is causing a time out problem with your printer.
Dec 28, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Suddenly all my pdf docs are opening in Adobe reader instead of Acrobat Pro. Even the Acrobat.exe file in my C:Program Files\Adobe\Adobe Acrobat 7.0\Acrobat folders opens Adobe reader instead of Acrobat...
Go to My Computer. Tools > Folder Options > File Types > Then Browse PDF Registered File Type . If you can see " Details for PDF extension " and you can see a change button, you can click that button and browse for your Acrobat Pro main program .
Aug 18, 2009 | Adobe Acrobat 7.0 Professional
Missing pdf maker files
Solution Remove Adobe PDF from the Disabled Items list in the Microsoft Office application. To manage your Disabled Items list in a Microsoft Office application:
  1. Open the Microsoft Office application (Word, Excel, Publisher).
  2. Choose Help > About [the application name].
  3. Click Disabled Items.
  4. Select Adobe PDF from the list, and then click Enable.
  5. Quit the Microsoft Office application, and then restart it.
View an Adobe Captivate demo of this procedure
If the error message continues to appear after you enable Adobe PDF, then check the security level for macros in Word:
  1. Choose Tools > Macro > Security.
  2. In the Security dialog, click the Security tab.
  3. Choose Medium or High.
  4. Do one of the following:
    • If you chose Medium, then click OK.
    • If you chose High, then continue with steps 5 through 7.
  5. Click the Trusted Publishers tab.
  6. Check Trust all installed add-ins and templates.
  7. Click OK.
PDFMaker and the right-click context menu should function again.
http://kb.adobe.com/selfservice/viewContent.do?externalId=329044
Thanks
proton
Apr 02, 2009 | Adobe Computers & Internet
Unable to create pfd with word 2007 document
That is normal, Word 2007 cannot create PDF documents, it can only save files on PDF but, being PDF non his own format, it will lose document format, and may not display pdf.
To create PDF you need the full version (not the free acrobat reader) of adobe acrobat, or a different adobe software (eg illustrator) that manages PDF.
See
Adobe Acrobat - How To Create Accessible Adobe® PDF Files Booklet
How to Create PDF Files
Jan 03, 2009 | Microsoft Office Professional 2007 Full...
Using publisher 2003. converting to pdf using adobe acrobat 7. live links are no longer live. How do I fix this?
If you are able to install Acrobat 7 properly, Launch Puvlisher, then you can goto File->Print
Selected PDF printer then click on print. You will get a save as box - > click on save. It will print to a PDF file.
Dec 23, 2008 | Adobe Acrobat 7.0 for PC
ADOBE 7.0 PDF
just do the following in acrobat 7 to downsave the pdf to version 6 so that you can open the same in your office:-
Go to the Advanced tab and click on PDF optimizer and change the Make comaptible optiopn to "Acrobat 5 or later" and then save the PDF.
not this pdf would also open in version 6
May 22, 2008 | Adobe Acrobat 7.0 for PC
Office 2007 professional and Adobe 8 Professional problem
Very simple fix. Now and then after an Adobe Acrobat update Office will disable Adobe Acrobat as it is an add on. All you need to do is re-enable Adobe Acrobat. In Office 2007 goto Word Options, Add-ons, and at the bottom of the page is Manage. Click on the down arrow and select Disabled Items and click on GO. Re-enable Acrobat and you should be fine. In Office 2003, goto Help and selects disabled macros and re-enabler Acrobat.
Feb 25, 2008 | Microsoft Office Professional 2007 Full...
Adobe Acrobat 7.0 for PC Logo
125 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
