Question about RCA Televison & Video
Only getting audio from Center speaker...
Only speaker that works is the center one. They all worked fine, and decided to stop working last night.
    Top Expert:
  • RCA Master
  • 12,223 Answers
Dear Sir:;
Will be a great idea to downoad a code exactly for your remote control:
reset and go to the web: www. fitness.manualsonline. com. give your model, and downloa for free.
Otherwise, you must go to web from RCA, and get the support for your remote control. Possible some Rom, or EPROM, can be faulty.
Sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 21, 2012
HOW DO I FIX MY CENTER SPEAKER
Rear and center speakers not working - Tom's Guide
www.tomsguide.com/answers/id.../rear-center-speakers-working.html
Sep 4, 2013 - Hey guys. I bought a Sony DVD Home Theatre System DAV-TZ140 about a year ago.And it worked perfectly, but all of a sudden my center and ...
Audio Troubleshooting 101: Getting Your A/V System ...
www.audioholics.com > Home Theater Setup > Home Theater Calibration
Jul 14, 2009 - Audio Video Troubleshooting 101: Get your AV System Working Again. ... It's time to put on your propeller head and get down to the business of fixing your system and enjoying it to its ... Problem: One or more of my speakers isn't working ... your Blu-ray player to your AVR and let the played do the decoding.
Tips for fixing common sound problems - Windows Help
windows.microsoft.com/.../tips-fixing-common-soun...
Microsoft Windows
Jan 05, 2016 | Audio Players & Recorders
Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
Yamaha Surround Sound HRT-6030
Hi!
maybe you select the Fader mode.. you simple select the fader balance to center then you hear the sounds coming out to the front fader mode.
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
My RX-V490 Amp. has no audio from Centre speaker.
Is your center mode set to "Phantom" instead of "Normal" or "Wide"? That would split the mono Center channel program and mix it equally with the programs for both front speakers so your brain would believe it's in the center.
May 17, 2009 | Yamaha RX-V490 Receiver
Center speaker and sub stopped working
if the sub was popping that either means the sub is getting to much power and blown that normaly happens when they pop, for the center speaker could check the wires maybe it came undone that could be a possibilty
Nov 16, 2008 | Kenwood VR-606 Receiver
All speakers are connected, but center 1 and 2 rears are not working.
Front and center speakers connected correctly and test sound works fine. Center speaker icon does not show on front panel of receiver (except during test) and i get no sound.
Nov 05, 2008 | Yamaha HTR-5840 Receiver
Onkyo TX-SR500 5.1 Receiver Last night
1-disconnect subwoofer first and test-and then disconnect surround speakers-and front speaker after-and later center speaker.ever time you disconnect you check the operation until you find the bad one(or two)which make the problem change its cable first and then change speaker itself.if all above failed contact the service center.
Jul 04, 2008 | Onkyo Audio Players & Recorders
Televison & Video Logo
19 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
