Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
Continous beep every 6 seconds
I'm having a problem with my ecs pm800-m2 board its only beeping continously every 6 seconds without any display at all.Im using the built in graphics display,any solution for this pls help.
  • oskeer Oct 30, 2008
    many thanks abhishekp removing the cmos battery and putting it back solved my problem.
    Problem Solver:
  • 16 Answers
There is either a problem with your memory or your BIOS settings. Did you recently change any settings in your BIOS? If so try resetting it. You may refer to the motherboard user Guide for help regarding resetting your BIOS/CMOS settings. If you cant find it you may also try to remove the CMOS battery on your motherboard for a few hours and then connect it back this should have reset your BIOS.
If you are sure you havent changed any settings then there may be a problem with your RAM or the slot in which the RAM is connected. Check it by using a spare slot on your comp. If it does nt work then you may have to replace your system RAM.
Posted on Oct 28, 2008
Dont know that how to connect the front pannel switch socket to the motherboard pins for pintium 4 computer
Is it an ECS PM800-M2 motherboard?
Uses a VIA motherboard chipset, (VIA PM800 / Northbridge chip, and VIA VT8237 / Southbridge chip)
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=453&MenuID=24&LanID=0
If so suggest you download the Motherboard User Manual.
Click on the - Download - tab.
(Features / Specification / Download / Cerification / FAQ / etc)
Click on the blue - Manual
(Driver / BIOS / Manual)
Go to the Bottom file -
English manual for PM800-M2
Release Date: 2004/5/3
To the Right of - Download - click on the country name nearest yours.
(Yeah, I know. Europe is not a country, it's a continent)
A small window will come up -
Opening PM800-M2_10.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the window, and click on OK.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name.
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
[DO NOT change anything in the second small window.
Windows knows where to put the file.
Just click on Next ]
In the last small window, there will be a red Adobe PDF icon, and the file name next to it.
You are now looking at a PDF file version, of the Motherboard Manual.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
If you cannot figure out the Front Panel header pinout, post back in a Comment.
Regards,
joecoolvette
Mar 14, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Need a manual for pm800-m2 motherboard
Hello Gerard, my name is Arman (online alias: thedrain)
Attached in the below hyperlink is the manual that you are looking for...
ECS
Jan 16, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Pm800-m2 rev:1.0
ECS Support > ECS PM800-M2 v1.1 > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=453&CategoryID=1&MenuID=18&LanID=9
1) Features:
2) Specifications:
3) Download:
Drivers, BIOS, and Manuals.
{Note* The second file down is the Motherboard Manual }
4) Frequently Asked Questions (FAQ)
5) CPU (Central Processing Unit. Another term used is Microprocessor, or simply Processor for short)
This page tells you what Processors are supported.
6) Pin-Out
Pin-Out's for the Front audio header, Front USB header, and the Infrared Port.
State the problem in a Comment
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
Motherboard
TAKE YOUR DDR CARDS OUT ,, AND SWITCH THEM,, ,,IF THAT DOESNT WORK TRY WITH ONE AT A TIME,, GOOD LUCK
Oct 05, 2008 | AOpen MX46-533V (91.89U10.061) Motherboard
Bios Problems
So you have the PM800-M2 board?
Visit - http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=453&DetailName=Bios&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
You can fine the latest bios there. And it also explains how to use it. But you need to confirm this is the board that you have first!
Oct 23, 2007 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
New board will not install com ports 1 & 2 and lpt1 printer port & floppy dr A
what you should have done was uninstalled the old motherboard drivers first as these drivers will be running the board although incorrectly, if you still have the installation disc run it as if to install, but it should show up with the option to uninstall the drivers.
Sep 26, 2007 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
184 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
